Question about Tascam 2488 Portastudio Multitrack Recorder System
How to chouse an out point when u press the pre master?
How
  • earworm Jan 18, 2008
    I give up! Can't get to the punch in and out to work so I can go to Mastering.
OK, NOW I CAN GO ON TO MIX. THANKS FOR THE HELP.
Posted on Jan 18, 2008
    Novelist:
  • 189 Answers
You have to choose your out point before entering premaster mode.
Use the transport keys to get to the point you want to end your mix and press 'shift' and 'set out' (mkI). For the mkII the end point is set by pressing the 'locate' key and the 'out' key.
Posted on Jan 06, 2008
I changed the batteries and now I can't open the safe- do I have to reset the code and if so how?
Assuming you've not changed the master code:
To Open the safe with the master code:
Enter the master code (pre-selected 123456) and press #. The LED will show -OPEN- and the door will open automatically and at the same time the LED will show "OPENED".
Jan 15, 2015 | Gary Laptop Computer Safe, Steel,...
How to reset dlinkap 1320
Hey Rolando,
On the back of the unit is a small button to reset. Use a straigtened paperclip to do so. Attached is an image of what it should look like. b86d4bfe-0100-4d89-87bc-74360b9790d9.jpg
Jun 06, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
How to pre bleed the master cylinder on my 1996 honda accord 5 speed
there are different ways to bench bleed the master depending on the tools available to you... did you receive a fitting, with or without a port for a small hose, in the new master box? if not then you should make one or get one at the parts store. you need to put the master in a vice (from the mount, not the body) and fill it with fluid. this is where the fitting comes in handy, you are going slowly depress the piston about half way at first having the fluid that comes out the port directed back into the reservoir with a hose. keep the hose submerged. if a vice and fittings are not available, you can mount the master in the vehicle, connect the line and fill with fluid. disconnect the line from the slave cylinder and submerge it in a container. press the pedal by hand slowly. make sure the line stays submerged and the master is never run dry. if everything is kept clean, you can reuse the fluid from the catch container.
Apr 17, 2014 | 1996 Honda Accord
Brake pedal spongy after replacing master cylinder and bleeding the syster
There is still air, presuming all brakes are in good shape and adjusted correctly. One issue is master cylinder PRE BLEEDING. If you do not pre bleed the cylinder, you may never get all of the air out. Parts stores sell a kit that has flexible hoses that connect to the brake line connections and submerge the other ends in the MC reservoir, bleed until no bubbles and from that point DO NOT let the fluid get low in the MC, or start over again.
Doc
Feb 08, 2012 | 1996 Chevrolet Suburban
I accidently changed my settings to itunes and now cannot get my pictures
please you aply a printer page setup again setting.
other
defolt printer is remu and again chouse a printer and chouse aplyok.
Oct 16, 2009 | HP Photosmart C7280 Printer
I finished one our ago my first recording i don't understand how to do to for pre mastering, because i want to do ace and evry time i read track too short, set out point... ?? give me how to do.a
Congratulations on your first recording! Mastering and pre-mastering is covered in much more detail in the manual (page 59 in the original 2488 manual) but I'll provide a brief explanation here for you.
First you need to enter pre-mastering mode. Do this by navigating through the menus to the 'audio CD' menu and then choose 'pre-master'. You'll see the word 'Mastering' appear in the LCD screen to indicate you are in mastering mode.
Basically you need to then set the 'out point'. The 'in point' is always 00:00:00.00. So just play your recorded song to the end (or where you want the master to end) and press 'shift' and 'set out' to set the out point there. A master has to be at least 4 seconds long which is whay you are getting that error message.
Next press record and play and the master will be recorded on two internal stereo mastering tracks (left and right). Master recording will automatically stop at the 'out point'. You can redo the master, undo a master, or copy the master tracks to any other two available tracks to preserve a copy and then go ahead and record another master. All effects, mixer settings, and fader movements are recorded as part of your master.
Best of luck.
Hope this helps.
Jun 15, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam dpo2 not burning a cd
You need to create a master first before you can burn it to a CD.
To create a master you'll need to set an 'OUT' point, then enter mastering mode (by pressing the master key so that it flashes) and then record your master by holding record and pressing play. The master recording stops automatically when it reaches the out point (the in point is always zero). The steps for creating a master are outlined on page 27 of the manual. Setting the in and out points can be found on page 30 and burning the master to CD is on page 67.
Hope this helps.
Cheers.
bd.
Dec 20, 2008 | Tascam DP01 All-In-One Recording Package...
Don't know how to Pre-Master or Burn to CD, please help me!
Don Q -
This answer assumes you have the 2488 mkI and not the newer mkII because the process may differ slightly on the mkII.
To premaster you first have to set an out point for the end of your pre-master (the start point is always zero). Go to the 'Audio CD' menu item and choose 'pre-master' under that. You'll see the word 'mastering' appear in the top left of the screen to let you know you've entered mastering mode. Make sure you have the tracks unmuted that you want to mix into the pre-master and have all of your eq, panning, etc set the way you want. Then hit record and play. The pre-master records to a stereo pair of dedicated internal tracks. You can redo the premaster as many times as you like which will overwrite those internal premaster tracks. You can clone the premastered tracks to a stereo pair of tracks, export them as waves or burn them to a CDR.
fnawesomewes - You have to press record and play to record your premaster.
Dec 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
77 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
