Question about Sylvania 6427TE 27" TV
Is my tv digital?
I'm trying to figure out if my TV is digital or not. It was manufactured in 2004. I cannot locate the owners manual either. I have dish network for my TV provider. Will I need to get one of those converter boxes?
  • 395 Answers
Your tv is not digital, but fear not the Dish network reciever is already digital. the satbox is digital and converts to your TV.
if you are worried about the conversion to digital this applies to off air broadcast (the stuff you get from an antenna in your local area). if you want to know if you can get HD on your set, well your out of luck there because that is a whole differant digiotal world.
to explain this better we have to understand the old broadcast world before we get into the digital world.
NTSC or National Television Systems Committee has been the standard that we have watched TV since the creation of TV (one size fits all). it is an anolog format that is plaged with problems in the broadcast world, snowy pictures due to poor reception, visible scan lines, and a whole host of other problems. so the US has adpopted a new broadcast standard ATSC or Advanced Television Systems Committee, formed in 1993 this committee came up with 18 formats to which a broadcaster may choose from to broadcast the message. of the 18 only 6 are HD or High Definition. this does not mean that your local broadcast has to provide HD but they must be digital in their broadcast (SD or HD). the advantage of going to digital is that you will never see a snowy picture ever again, you have the picture or you don't. also the broadcaster has now can broadcast multiple programs on their one carrier (frequency). so if you want HD you must have a set that can display this format and have the equipment to produce this to your set. the dish box you have may not be able to produce this signal to your NEW HD setso that may be needing to be upgraded.
Posted on Jan 26, 2008
I need the 3 digit code to program my remote to control the TV
Is the remote original to the TV? If this is a universal or cable/satellite service remote, follow programming instructions for that remote. Most have a auto programming feature which will locate that code for you by following that method of programming codes.
This code will have to be obtained from the manufacturer of the remote that you want to program. Refer to the Remote Owners Manual
Mar 22, 2012 | Sanyo DP19649 LCD TV
The bottom half of my screen has gone black all the time. I can not see any picture on the bottom half. My tv is less than a year old. I purchased it at Pamida in Nebraska City, NE , which has since...
Less than a year old tv.Ur tv still have the manufacture warrenty.Look in ur owner manual,call the tv manufacture 1-800.... numbers on the owner manual.Talk to their customers service department,what locations or what shops they hire to call,to take care their product that still in warrenty.
Oct 26, 2010 | Sansui HDLCD-4212 LCD TV
I am trying to program a Universal remote to controll my Tv but am unable to locate the four digit program code to g.o into the new remote for a Sony KDL-52XBR6 Tv. Can you help? Thanks
Try check in your owners manual. They might tell you what it might match up with. For the Direct TV remote the Sony codes are 10000 and 10834.
Mar 28, 2010 | Sony BRAVIA KDL-52XBR6 LCD TV
Standby Light Keeps Blinking. Can't get TV to come on.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expense, just locate any good qualified repairer.
Jun 18, 2009 | Daewoo DTQ-14U5SC 14" TV
Do I need a dtv digital converter box for my Symphonic SC313D 13 inch tv?
Pretty much a hoax on those diverter boxes. People ran out and bought them thinking that won't have reception. I have many years in maintenance and several years in nursing homes with different tv's in every room. Not once have I needed a box to pick up channels with or without cable. I myself get 16 channels with rabbit ears and thats enough for me. And I do own a combo as well and it has simple antenna and does me just fine. Depending on your location, the old tv antennas we use to put on our houses...they work amazing! Might be able to snag one on a freecycle or craigslist site. Good luck! :)
Jun 05, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
HD TV Conversion
Yes, this tv will need a converter box. It is not digital.
May 21, 2008 | Sansui TVM1916 19" TV
Is my tv digital compatible or not What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
Here are some general guidelines that may help:
TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
TV owners manual
try they have a large amount of owner manuals free. Try by entering your model number in their search window.
Mar 30, 2008 | Televison & Video
Tv manual
Go to the manufacturers website. If all else it.
Dec 31, 2007 | Televison & Video
Sylvania 6427TE 27" TV Logo
117 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
