Question about Samsung AS18A6RB Air Conditioner
Samsung split system air conditioner model as24bpa
Can you tell me the pipe sizes that go from the external unit to the internal unit
  • Anonymous Mar 14, 2014
    drain lecks
    Habit-Forming:
  • 109 Answers
15.88(5/8) AND 6.35(1/4)
Posted on Feb 25, 2009
  • 236 Answers
Suction-5/8"
Liq. line-1/4"
Max pipe length-50'
Max vertical hight bet. accu and fcu-25'
Posted on Jan 11, 2008
My Goodman split unit has bumping/knocking noise sometimes (not everyday) when heat first kicks on in the mornings only. What could this be? Also in defrost mode should the unit blow cold air?
May be the fan in the external unit is ruined or the internal pump is comming loose. But note that the pump also make much effort until the gas flows smoothly through the pipes .
Feb 27, 2015 | Goodman Heating & Cooling
My split air conditioner compressor fail is it due shot pipe length total pipe length less then 1.5 mt.unit is 1.5 Tr and room size is 160 sq ft.using steblizer.
A/C compressors fail because the system is overcharged, not enough charge in the system. Compressor can also fail if it's started before it has a chance to cool down first.
May 28, 2011 | Heating & Cooling
Our split system is not blowing cool air all the time? Can you tell me what the problem might be. Thanks
To get proper cool, keep cool mode. Temp setting minimum 3 degree less than room temp.Check indoor coil,air filter and blower wheel are cleaned.
Check gas pressure is good by keeping your hand on suction pipe (bigger size) which gives chillness.
Hope, helpful.
Jan 28, 2011 | Samsung Heating & Cooling
Wansa split a\c outdoor unit both pipe size
It depends on the make model of your unit , the capacity of the unit. It will be best to check the pipe sizes that are on the outdoor unit and the indoor unit that needs to be connected.
The copper pipes can then be decided after checking the length of your fitment.
Jan 08, 2011 | Heating & Cooling
Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
May 08, 2010 | Samsung AS18A6RB Air Conditioner
Water dripping from internal unit of J.B.S. split system air conditioner
Hi
This can be due to three reasons. The water drain pipe is block. Which can be sucked clean with wet/dry vacuum cleaner. The drain pipe behind the unit is not sloping downward away from the unit. Or the coils of the internal could be iced up. If this is the case the unit should be switched of until the ice is completely melted and switch the unit on again. If the copper pipes leaving the the condenser unit outside is starting to freeze up, the unit is short of gas. Call a A/C company to refill the gas and search for possible gas leaks.
Jan 26, 2010 | Heating & Cooling
Leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Dec 31, 2008 | Heating & Cooling
Oil trap for 2 ton split unit
Pipe size is okay, not that I know any better than the manufacturer, but I would recommend at least two and possibly even three oil traps in the vapor line on the way back up.
Jun 14, 2008 | Heating & Cooling
Samsung AS18A6RB Air Conditioner Logo
360 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
