Hello sir, hi your boot error can be caused by the following:
Your IDE hard disk is not the first boot, and wrong available boot on the bios. Check your BIOS setup for proper boot device.
Your IDE hard disk has bad serctors, since its P4, I estimate your drive to be 8 years or more. You may need to format the hard drive again and reinstall your OS (windows XP).
IF your HD cannot be formated, or no amount of windows installation can be done on the disk, its time to replace it.
Your IDE cannot be detected by the motherboard. check your BIOS configuration for proper hard disk setup.
Your IDE hard drive and your CD drive are both master or both slave, set the hard disk to master and the CD drive to slave. The settings can be seen on the case of the HD and CD drive.
Your IDE ribbon cable is bad.
Your 4 pin molex power cable to the HD is loose.
If I miss out something, please let me know. thanks.
no audio driver. when i open my music there is a error found. said- bad directsound driver: bla bla...
(More)
no audio driver. when i open my music there is a error found. said- bad directsound driver: bla bla bla.. error code: 88780078
