Question about Samsung DVD-P701 DVD Player
Reads NO DISC when disc is installed
I have two young children who use this player and I suspect the lens is dirty but I'm not certain. Any suggestions as to how to get at and clean the lens or check for other possible solutions?
Thanks!
Gene Kittredge
    Scholar:
  • 47 Answers
Hi Gene,
Try this kit from Walmart.
Regards,
Spare head 2
Posted on Jan 06, 2008
6ya staff
SOURCE:
No sound and keeps skipping
Does this happen with any disc or a disc? Playing a contaminated disc can cause heads to get dirty causing above results. Make sure discs are clean when inserted. (Young children can handle discs improperly and get fingerprints and other stuff on discs, resulting in dirty DVD heads) Purchase and use a DVD head cleaning disc. May have to use it a few times initially. Then make sure disc is clean before inserting. Wiping gently with paper towel dampened with water or vodka generally works to remove contaminants. Wipe only the bottom, not the top until it appears shiny.
Feb 16, 2016 | Sony BDP-S300 Blu-Ray Disc Player
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    Disc spins for about 30 secs then error reads wrong disc, I have 2 players, both same fault
    was the player reading discs before now? And how long have you been using this player?
    I suspect that the laser (lens) of this player is weak, that's why it cannot load discs.
    The symptoms is like that of a dirty or bad laser (lens).
    Use a lens lens cleaner to clean the lens. But if that doesn't solve the problem, then it means you will have to replace the lens of your player completely, in order for it to play/read discs again.
    Good luck.
    Aug 25, 2010 | Car Audio & Video
    I keep getting wrong disc error on my Daenyk DVD player and do not understand why I have played these DVDs on it prior and no Problem
    The reason the player keeps giving you wrong disc error is because the player is not reading the disc.
    the reason is either the lens is dirty or weak.
    To test if the lens is dirty, try to clean the lens with a lens cleaner and test the player DVD disc.
    To fix it if the lens is weak, open the player with the appropriate screwdriver, open the disc tray, and replace the lens with a new lens, test it with a DVD disc.
    Take care
    Jun 14, 2010 | Televison & Video
    My Akai dvd player shows "no disc" after loading a dvd. The tray sometimes makes a grinding noise when opening and closing as well.
    The reason the player is not reading the disc and showing no disc is either because the disc is not sitting properly on the lens from the disc tray, or the lens is weak or the lens is dirty.
    To test if it is the disc tray, open the cover of the player with the appropriate screwdriver, place a disc directly on the tray and apply a little pressure on the tray, if it reads the disc, then it is the tray.
    All you have to do is to adjust the disc tray and screw it tightly.
    To test if the lens is weak, try several DVD disc on it,and test them also on another tested ok player, if it does not work on your player and works on other players, then the lens is weak.
    to fix this, get the appropriate screwdriver, open the cover and unscrew the disc tray.
    You will gain access to the lens, carefully disconnect the lens and replace it with a new lens. then it will be ok.
    To test if it is just that the lens is dirty, clean the lens with a lens cleaner and test a DVD to see if it will work.
    Take care.
    Jun 14, 2010 | Akai DVPS760 DVD Player
    Dvd player is saying no disc
    how long have you been using the player. There is every tendency that the lens (laser) of your player is weak and that's why it cannot read or play discs.
    The lens (laser) is what makes the player reads discs, and if the lens is weak/dirty, there is no way it can read or play disc.
    Get a lens cleaner and use it to clean the lens, if that does not solve the problem, then its means, the lens needs to be changed completely.
    Good luck.
    Apr 21, 2010 | Dynex DX-PD510
    The Disc begins to be "read" and then stops suddenly, and restarts "reading" the disc until an error sign occurs on the screen
    Good luck.
    Apr 17, 2010 | Cyberhome CH-LDV 700B Portable DVD Player
    Disc error
    how long have you been using the player. There is every tendency that the lens (laser) of your player is weak and that's why it cannot read or play DVDs.
    Good luck.
    Apr 17, 2010 | Toshiba SD-2815 Multi-disc DVD Player
    Changer works but display reads no disc
    the lens on the optical pickup is dirty and needs cleaning. they sell a lens cleaner disk at any electronics store. you also might want to blow any dust out of the unit with canned air to prevent it from happening again.
    Dec 17, 2009 | Pioneer PD-M603 6-Disc CD Changer
    Samsung DVD-P701 DVD Player Logo
    60 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
    Ekse
