Kodak EasyShare C613 Digital Camera
Problem for Kodak EasyShare C613 Digital Camera
Camera shutdown when batteries ran out and will
By des_tekki on Nov 08, 2009
camera shutdown when batteries ran out and will not power up again with newly recharged batteries.
Solution #1
posted on Nov 08, 2009
Not Rated)
BillB-SA
Rank: Wiz  Kodak Cameras & Camcorders  Expert
Rating: 85%, 365 votes
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Was this helpful?
Yes
No
Popular Solutions for Kodak EasyShare C613 Digital
Questions and Unsolved Problems for Kodak EasyShare C613 Digital
Do you recommend Kodak EasyShare C613 Digital Camera?
Answer
Answer
Our C613 is not reading the memory card when it is turned on. It goes straight to built in memory... (More)
Answer
Lens does not retract even with new batteries. How do I remedy this problem?
Answer
You can only see a partial picture on the LCD screen there are lines on the C613 camera. Screen is... (More)
Answer
camera not turning on and off properly , it wont take pictures when i do get it turned on, digital... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kodak EasyShare C613 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 761
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
