In Dash Receivers
Generic problem for all In Dash Receivers
Am car radio not working
shared by 3 users
posted by jimarmstrong on Jan 06, 2008
I have a Ford pick up truck that the am radio does not work with the engine running. It works on the accessory when the key is turned to it, but the minute you turn the key to the on position or with the engine running I get only static. The plug wires are good and the plugs as well. I can't find a noise suppressor in the system. what should I do? Antennna and cable are new. thanks Jim
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by Guest on Oct 14, 2008
I have am radio problem. Where do you fine a noice suppressor?
Posted by Guest on May 12, 2008
My radio developes noise on & off in my '99 Ford Ranger. I'll be driving along and all of a sudden I get radio noise. Gets worse when I step on the brake or turn on a turn signal. Then goes away as quickly as it came on.
Best Solution
posted on Jan 14, 2008
FixYa! (100)
pierre235
Rank:Guru Guru
Rating: 87%, 466 votes
make sure the radio is well grounded and you got to find a noise suppressor for the power lineof radio cheers
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on am car radio not working:
I don't want to Accept this solution
Can you Help with these In Dash Receivers problems?
Kenwood KDC-138 FM / AM Receiver
during normal operation the cd gets warmed up my another...
In Dash Receivers
RP0253n1513960 and its not 2858 or 1521
Durabrand WD810
I accidentally put in a cd with gum into my car cd player....
Naxa Electronics Naxa Stereo AM/FM.MPX...
will not turn off need to know how to program songs
In Dash Receivers
The dashboard lights on our Ford Galaxy (2002) have gone...
Loading problems.
Repair Service
Find In Dash Receiver Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
