i have a pro comp pc9001 distributor multi-spark box with a pc91 coil..my problem is where does the distributor hook up to ..it has a black wire and a black wire with a thin yellow stripe .. which wire goes where .. what is the polarity of each wire
hi, i have a el wagon and the centeral locking ,keeps going up and down, have not found a solution...
(More)
hi, i have a el wagon and the centeral locking ,keeps going up and down, have not found a solution as yet seems to happen when the car is out in the hot sun, in the shade its ok.
My Colman forced air heater is cycling acording to the thrmastat but wont heat up. The trouble...
(More)
My Colman forced air heater is cycling acording to the thrmastat but wont heat up. The trouble shooting light flashes three times.What part do you think is failing?
evertime we lower thermostate at night then raise it in the morning the resit light is flashing then...
(More)
evertime we lower thermostate at night then raise it in the morning the resit light is flashing then we have to push button to resit furnace weshould noy have to do this help
when i open the window of my car than the locks starting up and down regularly and when i start the...
(More)
when i open the window of my car than the locks starting up and down regularly and when i start the ignition it stops. but i can't open it in starting position because it starts up and down in starting position as well. thank you
