posted by mrsocks on Jan 06, 2008
unit will not record
1 Other User Has The Same Problem
Comment by Barcelo, posted on Feb 19, 2008
I also am having problems that just started after 2 good trouble free years of use. What it will do is record then on playback it will pause start pause and pixelate which is very frustrating.It only records on DVD+ but wont recognize maxell or memorex it only seems to like Dataware brand.I tried using an expensive dvd cleaning disc but it says no disc so I cant even use the disc.I took the unit apart to clean it and it appears to have a regular pc dvdrw drive same 5 volt power and all can I just install a pc recorder will it work? Thanks
Best Solution
posted on Jan 06, 2008
try cleaning the lens of your dvd if that does not work have a tech look at your dvd it could be having a problem in the recording circuit which is controlled by a chip.good luck
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Sanyo DRW-500 DVD Recorder
Email this problem
Email this problem
Can you Help with these DVD Players problems?
Sanyo DVD 600 stuck on recpause
Any idea how to unstuck it? Answer This...
Sanyo DVR-DX600 dvd recorder
On the above machine the remote... Answer This...
Sanyo DVD recorder DVR-DX600
Hi, could not get the manual... Answer This...
Repair Service
Find DVD Player Repairman Near You:
