Do you mean the encryption settings to allow computers and laptops to connect to the wireless router? If so open the IE browser and type in the Belkin's configuration IP address (http://192.168.2.1) and login to the router. If you diddn't change the default admin login then the password is blank, just press enter. Then go to the wireless settings and note the SSID and encryption settings. Then configure the wireless cards in the computer/laptop with these wireless settings.
Wireless Router and WiFi processes: Belkin Router □ Cannot disable or disconnect the...
(More)
Wireless Router and WiFi processes: Belkin Router □ Cannot disable or disconnect the wireless connection by hitting the disable button □ To disable you have to go to the task manager and end the task □ Sometimes the router does not disengage or disconnect even after the computer is cut off (light stays on) □ After disabling the WiFi connection it will not enable again. When trying to enable the error message comes up ? Connection Failed? ..Can only be enable again by shutting down the computer entirely and restarting again. □ Have to unplug electrical connection to disable the router
Hi i have a belkin wireless g plus mino usb network adaptor running windows XP the computor finds...
(More)
Hi i have a belkin wireless g plus mino usb network adaptor running windows XP the computor finds the devise but will not install it i have downloaded the drivers from the net but cannot find the softwhere can you help please
