After a paper jam, my Deskjet 895cxi now cannot send the paper through the rollers for printing. Start up is as usual, but when it is time for the paper to go through the rollers, the printer makes a weird noise and the paper does not move.
You may open the rear door to check for any paper jam in side
or if it still gives error rotate the roller in upward direction till you get one locking sound, restart printer and check printing
if you still find grinding noise from printer, its pickup roller gear may be worn-out generally and need to be replaced
contact service person for further repair
Clearing paper jam in a printer is simple almost seven step
procedure depending on the printer. Paper jam is the term used to refer to the
scenario where your paper fails to come out of the printer during the print
process. When you send a document to the printer, normally the printer prints
out the document on a paper; then you can pick up your printed copy. When the
paper gets stuck in the printer, it is said that paper has jammed in the
printer "paper jam".
Even if you are not a technical person, you can conveniently
clear paper jams. All you need is to follow the set of procedures outlined
below.
Good luck & God bless!
