Home | Apple | iTunes | I am having trouble lis...
Apple iTunes
Problem for Apple iTunes
I am having trouble listening to some songs that I
By daisymay100 on Nov 08, 2009
I am having trouble listening to some songs that I have brought and downloaded from iTunes.
My current laptop is a Toshiba running Windows Vista Home Premium.
iTunes down loads the song into my iTunes library, however sometimes, and particularly if I have purchased an album I am not receiving/or can't locate some of the ''m4a'' files associated with some songs.
When I click on the song to play it, nothing happens. If I right click on the song and select ''show song in Windows Explorer'', I am directed to that area.
Sometimes the missing ''m4a'' files can be found there, and it is a simple matter of ''drag and drop'' the missing ''m4a'' into my iTunes Library and the song will then play.
However on other occasions their is no ''m4a'' file, only a file detailing the name of the song. Drag and dropping this file into my iTunes Library has no effect, I can't play the song.
Any help with this would be most appreciated.
Regards
Mark
Comments:
Nov 08, 2009
- Thanks for your reply Randy, Your right iTunes downloads your songs automatically to your iTunes Library, but beneath all that user friendly iTunes interface it has to save the song as a "m4a" file on your Hard Drive. For info, a Ring tone is a "m4r" file. At least that is the case with a Windows Vista PC, not sure of the procedure on a Apple. In my case when I down load a song from iTunes it saves it to the iTunes Library (well most times) and the actual music file (m4a) is saved to; Desktop/mark/Music/iTunes/iTunes Media/ Music/Artist/Album/ m4a file. All songs that are in your iTunes Library are located in the above "file path". There is a "Compilations Folder" located in the Artist Folder The above "file path" would apply to all Windows PC's I think. A quick way to find your "m4a" file for a particular song/track/album is when in your iTunes Library "right click" on the song, this opens a window in iTunes where there are a multitude of options are available. If you select "show in Windows Explorer" you end up at the "m4a" file for the particular song or songs in the album. In my particular case, if everything has functioned as it should I "left click" on my song in iTunes and it plays (happy days). However, of late when I buy and download a track from iTunes one of three different things happen; 1. The song has down loaded as it should and I can play the track as it is intended by Apple/iTunes. 2. I "left click" on the song, and nothing happens. What I need to do then is what I have described above (right click on the song/show in Windows Explorer etc), if I am lucky when the song folder opens, the "m4a" file will be there, there will also be another file as well which I have called a "song file" it does not seem to serve much purpose as I have deleted it with no adverse repercussions. Anyway, all I do after locating the "m4a" file is drag and drop it into the iTunes Library, and the song then plays as it should, and I experienced no further problems. This is a "one time' fix :-). 3. Where it all turns nasty is that after having done the above (para 2), and opened the song folder, there is no "m4a" file just the "song file" which to my knowledge has no use. Therefore I can't drag and drop the "m4a" file into the iTunes Library. So even though the song appears in the iTunes Library it won't play...The Case of the Missing m4a File... Incidentally, you can play all your iTunes Library music from from the above file path, and "by-pass" iTunes altogether. Why you would want to do this ???, just an option... Cheers Mark
Nov 09, 2009
- Thanks for the second repy Randy, for some reason I can't locate your second responce on the site via my laptop but am able to read it on my iPhone??? Anyway, I had/have the boxes you mentioned checked Preferences/Advanced/Keep iTunes Media Folder Organised etc. My files appear in the two places you mention (Libary and Purchased), in addition to the iTunes Media Folder on my hard drive. As for the connection dropping out. I don't think that was the case, but may have been so. I am of the understanding that iTunes would download any missing files the next time you logged in? If I visit the iTunes Store and attempt to purchase the songs a second time iTunes warns me that I have already purchased and downloaded the songs. It's a curly one, most probably something very simple, can't see the forest for all the tree's. Thanks again, I'll let you know how I get on. Regards Mark
Best Solution
posted on Nov 08, 2009
Helpful)
randyprevost
Rank: Wiz
Rating: 81%, 165 votes
When you purchase songs in iTunes, it gets downloaded automatically to your iTunes library. I'm puzzled by the cases where you say "there is no m4a file, only a file detailing the name of the song." What is it that you are dragging and dropping if there is no file?
The only thing I can think of is that the albums you download is a compilation, and the songs are being saved into different folders by artist and not by album.
Comments:
Nov 08, 2009
- Yeah, I understand what you're saying. After downloading an album...
  • All album tracks are listed in the library
  • Some tracks don't play when clicked even though iTunes knows where the file is with "show location ..."
  • Some tracks are missing the audio files
Under "Edit" click "Preferences" the select the "Advanced" tab. Check the box for "Keep iTunes Media Folder Organized." That may help, but not if the files simply are not downloading. The files I download appear in two places in my library under "Music" and under "Purchased." Does that also apply to yours? Did your connection drop while you were downloading the files?
Hope this helps.
Randy
Remember to rate this solution and mark it solved when applicable.
Nov 18, 2009
- Mark,
You could try the "File > Consolidate Library" option. It can be tricky so select your options carefully,
The "Consolidate Library" feature will scan your hard drive for all playable iTunes media and copy them into a single location and catalog them. You can choose to leave the files in their current locations, or move them. Pick the one that suits your needs.
Hope this helps.
Randy
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Apple iTunes
Questions and Unsolved Problems for Apple iTunes
Do you recommend Apple iTunes?
Answer
Answer
Registry settings used by the itunes drivers for importing and burning CD`s and DVD`s is missing.... (More)
Answer
when i am downloading itunes it gets so far then comes up with connection was reset?
Answer
Whenever i click the itunes icon on my computer it doesn't open. whenever i click it agai it doesn't... (More)
Answer
I am not able to download and run itunes. I use to be able to run this on my computer, not able to... (More)
Answer
itunes drivers for importing and burning CDs/DVDs missing
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple iTunes:
Top Graphics Pub... Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Graphics Pub... Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
