Whirlpool Duet GHW9150P Front Load Washer
Problem for Whirlpool Duet GHW9150P Front Load Washer
Has code f2
By curtisdenell on Nov 08, 2009
has code f2 will not start up,or reset when u un plug it
Solution #1
posted on Nov 08, 2009
Not Rated)
jsrock516
Rank: Guru  Whirlpool Washers & Dryers  Expert
Rating: 96%, 6750 votes
"F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. In most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Was this helpful?
Yes
No
Solution #2
Not Rated)
rbhomesource
Rank: Guru  Washers & Dryers  Expert
Rating: 86%, 27 votes
check that the water supply lines are not kinked or clogged, and that water is coming to the washer
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Duet GHW9150P Front
Questions and Unsolved Problems for Whirlpool Duet GHW9150P Front
Do you recommend Whirlpool Duet GHW9150P Front Load Washer?
Answer
Answer
my washer gives me an error code F-2 and will not start cycle water starts the nothing
Answer
I can not get the door to lock so the washer wil not start
Answer
we can't get our washer to start. we keep getting a message that says DL and then F - lights are on... (More)
Answer
hi there, i have moved to a new place which has the whirlpool front load. everytime i want to wash a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool Duet GHW9150P Front...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14841
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
