Acer Aspire 5315 PC Notebook
Problem for Acer Aspire 5315 PC Notebook
Aspire 6920 fell off bed screen messed up can i
By amy_roberts on Nov 08, 2009
aspire 6920 fell off bed screen messed up can i replace myself
Solution #1
posted on Nov 08, 2009
Not Rated)
TimHuntJr
Rank: Guru
Rating: 88%, 19 votes
Yes you can replace the screen yourself but be warned its not hard but you may crack or break something else in the process with that said check ebay most of the time you can get a replacement screen make sure your battery is out and your laptop is unplugged
on your laptop there will be some little rubber tabs on the plastic framing surrounding your screen take the tabs out with a little flathead screwdriver once thats done if there is any ruber stripping pull them off to and check for screws once all screws are unscrewed start from the sides with a flat screwdriver and pop the front platic off it snaps on and off once you take all the screws off once the plastic is off see where everything is plugged in from your cracked lcd unplug them it should be 2 conections i think, if its a ribbon you will most likely have some little tabs you will have pull back then the ribbon will come rite out then replace the old screen with the new on if you need any other help just ask ill be around ...
Was this helpful?
Yes
No
Solution #2
Not Rated)
Geekman
Rank: Guru  Acer Computer Hardware  Expert
Rating: 85%, 1723 votes
Is the screen cracked?
If it in not cracked the fault maybe the inverter which supplies high voltage to the CCFL lamp or the CCFL lamp maybe faulty.
Yes you can replace the screen and if you need service, parts and DIY info then have a look at LCD Parts WEB site - click on this link to their WE site :-
www.lcdparts.net
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5315 PC Notebook
Questions and Unsolved Problems for Acer Aspire 5315 PC Notebook
Do you recommend Acer Aspire 5315 PC Notebook?
Answer
Answer
need to replace acer aspire 5314 hard drive. Where can I find one?
Answer
power adapter will not charge and battery won't hold a charge
Answer
the screen refreshes on igoogle anytime the cursor is moved over the screen . This is the acer... (More)
Answer
Page down and page up keys don't work Also, can't scroll using touchpad Thanks
Answer
i have a acer aspire 5310 runnin on windows 7.i have no sound wth my vga cable just pic,i tried a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 5315 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 755
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
