- My husband cut and plugged the water line. The problem now is he shut off the water behind the fridge...and there is a tube that comes out from that- there is a very slow leak coming from there...But it isnt connected to anything..any ideas?? Thanks so much!
Your drain may be freezing because of a blockage down line from the defrost condensate drain. But there are some models no matter what you they seem to freeze the condensate drain opening shut. Make sure your refrigerator is not leaning so the water will pool to one side and slowly freeze up until the drain closes. Below is a link to a short Tubehow to get the drain unplugged but every situation is different. Let me look over your models design and if I see something that may be causing this to happen I will try to get that point out to you, Click n the links below starting with the first and please respond so we can stop this mess, Please let me know what you may run into as far as problem getting to certain areas, Thanks, Sea Breeze
- If this don't help please tell me the problem and also go over the links I sent. There are many ways this can happen. Thanks, Sea Breeze
Nov 10, 2009
- Wow, I always know when there is a leak you get them from all places. I have hundreds of service manual and I believe your model has a filter below and inside the kick plate. Look around the door frame near bottom and behind the fresh food section door. Sea Breeze
Nov 10, 2009
- Click Here=> Whilrpool Refrigerators Enter model number. Or Click here=> Appliance That way I can help you better, Thanks, Sea Breeze
Nov 10, 2009
- Here are the parts I think you ar looking for HERE=>Water Valve Kit- Double Outlet It does depends on the model number because the kit comes with snap on fittings and new hoses, Thanks Sea Breeze
Nov 11, 2009
- You know the more I read your post it is possible that the condensate pan below the refrigerator and near compressor may be leaking or have a hole in the pan. If the idea of cutting the water off to dispenser and ice maker does not solve the problem it goes back to the condensate drain line problem. Every time the refrigerator defrost water travels down to that pan where the heat from condenser and fan evaporate the water back into your home. If that pan is plastic and cracked or steel and rusted a hole through it that could be the problem. Sea Breeze
Both freezer and the Refrigerator does not work. The compressor is always hot. The water is running...
(More)
Both freezer and the Refrigerator does not work. The compressor is always hot. The water is running fine. The bottom of the unit is cleaned from dirt.
Why does our whirlpool gold refrigerator lose power? It will completely lose power and I have to...
(More)
Why does our whirlpool gold refrigerator lose power? It will completely lose power and I have to pull it out from the wall and unplug it and then plug it back in to get the power to come back on and then it is fine until the next time it loses power. This happens at random intervals.
I have a model ED5GTGXNO 25.3 CU.FT. with water & ice in the door. The water works but the...
(More)
I have a model ED5GTGXNO 25.3 CU.FT. with water & ice in the door. The water works but the ice does not. It looks like water is not coming into the icemaker. The wire switch is in the down position.
