Question about Acoustic Research ARS108 Speaker
ARS108 gone Power light is off, 0.5A fuse is blown. If I replace fuse it blows again. Noticed 12 uF/50V NPO cap at the speaker (SPK-,SPK+) blown. I can replace that but I am concerned with the power amp S53AMI being gone as well. Tried it again without the cap and I get a low hum noise out of the speaker. Any suggestions ? Box is good, speaker is good, hate to waste it for a stupid Amp board
    Problem Solver:
  • 6 Answers
Since Acoustic Research went out of business, I too have been looking for a solution similar to yours. I may have found an alternative to throwing away this really nice speaker. I found a company on the web that appears to sell an amp that may fit nicely into this speaker enclosure for $99.00. Check it out...
http://www.partsexpress.com/pe/showdetl.cfm?DID=7&PartNumber=300-805
Tenderfoot56
(I'm not in any way associated with this company, just a suggestion)
Posted on Feb 28, 2008
Fuse 12 20A keeps blowing. controls OBDII and cigar lighter
Hi John!
  • There is a short in the Circuit. Do not put any more fuses in it.
  • Take it to the Electric Shop to have it diagnosed.
Good Luck,
JP
Jul 03, 2015 | 2005 Ford Excursion
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
Hi, my LCD Polaroid FLM-3701 went through a power outage and now doesn't get power any more. The power led doesn't show any light. I saw a capacitor repair kit available, and four 680 uF capac
The power supply fuse should be next the the ac input plug on the power supply. It should be a long cylinder type fuse, probably a T6.3AH/250V. You will want to replace those caps ASAP
Nov 05, 2012 | Polaroid FLM-3701 Television
Loud hum when powered on
its most likely bad capacitors inside the monitor. take it apart and look for 2 big black caps, there located right by the plug for the power supply on the PCB. they should say 25v 6800 uf.
if they are bulging out on the top and or have goo oozing out of them, there bad. these caps commonly go bad in these monitors because there rated WAY too low.
If you have to replace them, id go with some 50v 6800uf caps. they will be bigger and you'll have to solder leads and mount them elsewhere off the PCB, but you will NEVER have to change them again in your lifetime! (prevented no one else messes with it! )
Sep 26, 2012 | M-Audio BX5a Speaker
Where can I get a new control pod from for razer mako 2.1. Or where can you get it fixed in the UK?
The solution is that there are two capacitors in the subwoofer amp that need replacing. A qualified electrical repair shop can do this easily for you. If they put it on the oscilloscope, you'll see that the issue is one of two caps :
Best solution is to replace both the capacitors. One capacitor is 47 uF/50V, and the other is capacitor is a 100 uF 35V.
Voltage (Voltage capacitors) must be of higher capacity, not lower. By putting in slightly bigger capacitors, it will more resilient to dirty power, which I believe is the reason why it went bad in the first place - put these on a proper power surge/filter to protect them.
May 14, 2011 | Razer Mako 2.1 Speakers
Sounds as if the woofer is blown. seems t be a vibrating noise. this will be the third time fixing this problem.
get some higher rated speakers as this will happen time after time, or you could turn the bass down lol
Apr 08, 2011 | M-Audio BX5a Speaker
I have the velodyne DLS4000R and it keeps popping at high volumes ??
Popping ????? if popping sounds mechanical: chek for speaker blowned (replace or repair speaker)
if popping sounds electronic: chek circuitry.
Apr 03, 2011 | Velodyne DLS4000R Subwoofer Speaker
Failed Repair Job. A friend of mine called a loocal repair shop to fix their LG50PC3D 9 x 10V 3300uf 105c Capacitors on the Power Board were swollen 1 x 50v 680uf 105c Capacitor on the Power board was...
replacing the 10V caps with 25V caps is perfectly fine. In fact, if it was manufactured like that, those caps may not have blown.
Replacing a 680uF with a 1000uF could be problematic depending on it's function.
680uF is pretty specific when 500uF and 1000uF are much more common and therefore cheaper - one would think that the engineers would have tried using those in the design rather than a 680uF - makes me think the value of the cap is important to the frequency of the circuit it's in.
Other concerns might be whether he got any of them in backwards or not.
That's a rookie mistake, but still an easy enough one to make (for a rookie).
Also, with that many swollen caps, I wonder if there were any that leaked out the bottom before swelling at the top (IE - if some caps were missed in the replacement procedure)
Also, with that large a number of caps gone, other components may have been compromised or blown.
I'd be testing the transistors around those caps (most likely punched through rather than open), looking for fusible links (surface mount fuses, 0 OHM resistors) that may have opened up etc.
The initial attack on the problem was basically correct, and in many cases probably would have fixed it (if say the 680uF cap was functioning as a ripple filter).
But when that didn't fix it, a deeper analysis should have been done to complete the repair (including locating a 680uF cap).
Feb 27, 2011 | LG 50PC3D 50 in. Plasma Television
Audiosource AST-Sub 10 subwoofer. it blows the fuse when turn on.
It sounds like your audio amplifer has a short (probably the out put transistors or module). This should not be an expensive epair.
To check your speaker you can use an ohm meter. First, pull of one of the two wires that connects at the speaker. You should read 4 to 8 Ohms. Also you will hear a little pop through the speaker as you touch the wire. You can also use a 9 volt battery in the same way.
Good Luck
Jul 25, 2009 | Audio Players & Recorders
Blown fuse??
there is an underlying cause for the fuse to blow. if something shorts out you would rather a 40 cent peice goes then the unit causing a fire. disassembly is require... look for obvious burnt parts first.
Robert
Sep 01, 2008 | MTX SW2 Subwoofer
Acoustic Research ARS108 Speaker Logo
259 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
