Question about Polaroid iZone 300 Digital Camera
Frozen Camera My green light stays on solid. I can not take pictures or turn off my camera. I have to press the reset button to turn off camera. Once I turn it back on the same process happens
  • 68 Answers
These cameras have a firmware issue that makes this occur. I have been unable to locate information regarding possible firmware upgrade for this camera.
Posted on Jan 07, 2008
I have a Sony H5 camera. I just notice that if I go to take a picture I press the button, the green light flashers and then it snaps it with pressing all the way down
Greetings - That's how the camera was designed to work. Pressing the shutter half way down makes the camera auto focus. When it's in focus it turns solid green and you then press the shutter all the way down.
I suggest you read the getting started guide that comes with your camera or on line HERE.
Enjoy your camera and thanks for using Fix Ya
Mikeywaf
Apr 11, 2011 | Sony Cyber-shot DSC-H5 Digital Camera
Hi ,my sx20 reset all button is disabled. how can i reset my camera settings?
Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 20, 2009 | Canon PowerShot SX20 IS Digital Camera
Frozen, locked up with blinking green light.
If you cannot get to "reset" in the camera menu, then here is how to do a manual reset...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 07, 2009 | Cameras
S9000 canon printer ink tank full
Hi
Try this see if work for you.
may work
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 02, 2008 | Canon i950 InkJet Photo Printer
Camera wont take snap
Because the camera has Mechanical Focus the camera button has 2 Pressures, Holding The first 1/2 of the button press will enable to Mechanical Focus to work, And then once the green dot is shown telling you its in focus, pressing the button all the way down will then take your picture !
Oct 25, 2008 | HTC G1
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Unable to take Pictures
So, you're using Ni-MH batteries already, once you've turned it on and then you have to press on the PLAY button to view pictures, i need you to double check the battery type option of your camera by doing the steps below:
- Press MENU
- Scroll to the right until you are in SETUP 2
- Go down to Battery Type
- Switch it over to Ni-MH (for Rechargeable batteries)
- Select Alkaline (for Non-rechargeable batteries)
- Press MENU/OK for changes to be saved
Turn off camera for a few seconds so settings will be refreshed.
Turn on camera without pressing on the PLAY button to double check if it works.
If it does not work still, try to turn on again camera and immediately press on PLAY button to view pictures. Try to press again on PLAY button so you'll be on the mode to
take a picture.
If it still does not work, can you please try Non-rechargeable batteries (Alkaline) with your camera if it won't work with the Nickel-metal Hydride (Ni-MH) Rechargeable batteries.
Make sure you have set properly the battery type of the camera under SETUP 2 for Alkaline.
take a picture.
If it still won't work, then you have to send the camera for Repair.
Register camera online:
- Go to www.samsungcamerausa.com
- Click on Customer Service
- Register under Option 2 Box
- Fill out the required info
- Read instructions
- If website asked you to upload a receipt, just skip that
step and leave it blank
- Take note of the ASC address and online ticket number
that will be generated at the last step
- Turn-Around-Time will be 7-14 business days
Do the following:
- Include a copy of receipt in the box to avail of the warranty
- If you don't have any receipt, include a copy of credit/debit card statement/cancelled check that was used to purchase the camera
- Exclude all accessories when sending camera for repair
(No batteries, memory card, strap, cables, manual, CD)
- Write the online ticket number on top of the box
- Use another box and sealed it properly to avoid damages during shipment
- Check repair status using Online your zip code and phone number as you proceed on the Repair status of the website
Sep 14, 2007 | Samsung Digimax S630 Digital Camera
Pentax M20 Green Mode Stuck
i just had the same problem....
here's how i fixed it...
turn it on... then as it's loading up... hold the "menu" button
i think this forces it to stay on...
i changed the green button to be something else... not green mode
then i just turned it off and on again
Aug 20, 2007 | Pentax Optio M20 Digital Camera
Problematic Camera
I just discovered that the real problem is a STICKY SHUTTER BUTTON, staying down after taking a picture. This prevents the green ready light from coming on until I jiggle the shutter button. It has actually started to be hard to press, making a definite clicking sound as it goes down. I can even feel it catch on something. If I move it around a bit, it will eventually come up, allowing the ready light to reset. Can this be cleaned? How about adding a drop of WD40 or something? Anybody ever take one of these apart? Any tips as to how to do it safely??? Thanks.
Sep 13, 2005 | Kodak EasyShare DX4530 Digital Camera
Why doesn't the shutter button on my EasyShare digital camera work?
The cause and solution may include one of the following: The camera is not turned on. Turn on the camera. The camera is processing a picture; the camera Power ring light (on the Mode dial) blinks green. Wait until the light stops blinking before taking another picture. The card or internal memory is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The shutter button was not pressed. Depress the shutter button completely down. There was a failure in the focus and/or exposure. Press the shutter button halfway to set the Auto Focus (AF) and Auto Exposure (AE). When the AF/AE indicator turns green, press the shutter button completely down. The battery is exhausted. Replace or recharge the battery
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Cameras Logo
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
