Question about Acer Aspire 5100 Notebook
Acer 5100 laptop mouse/keyboard not working
I think the hard disk is failing, but I can't figure out how to transfer my files before it fails completely because the keyboard and mouse are not functional. Any ideas?
  • AnnoyedSal Jan 06, 2008
    I've tried attaching an external USB keyboard and mouse. Neither works, so I can't get to the solution you propose
    Scholar:
  • 48 Answers
Your local electronics store has a USB keyboard and mouse port dongle. Or if you have a USB keyboard or mouse. Once you get functionality, choose Start>Run and type in "CMD" without quotes and hit enter. You will get a black box with a command line, enter:
chkdsk /r
Windows will inform your the disk is in use and cannot perform, you choose yes and it will do so upon the next restart. Restart the machine and let it run the disk check utility. Place your ear on the palmrests (usually where hard drive is located inside bottom half of laptop). Listen for sudden hard clicks, similar to huccups. When it makes those noises the hard drive light usually stays solid, afterwards the hard drive will repeat the same "bad sector check" sound. Finally, if you notice the process taking more than a few hours, your disk is in trouble. Recover the data using an external drive bay (also at electronics store) and place the drive inside the bay and recoverit to another computer. Order a new hard drive, intall, and re transfer your files by any media or network.
Posted on Jan 06, 2008
6ya staff
SOURCE:
When I turn on the Acer 5100 the screen comes on and the programs run but there is NO keyboard , touchpad, or mouse response. So I can't do anything.
Very bad reputated problem on ACER laptops... The southbridge chip is failing or badly welded on the motherboard.. Need to replace the motherboard (or to find a NASA's technician being OK for reparing the CMS welding...)
Feb 09, 2010 | Acer Aspire 5100 Notebook
My acer 5100 aspire laptop's mouse and keyboard
I think you have disabled them.
There should be a key to enable mouse and keypad.
Jan 27, 2010 | Acer Aspire 3680 Laptop
Acer Aspire 5100-USB, Touchpad, keyboard all quit working.
Bad motherboard or a failed attempt at a bios upgrade/flash
Jul 21, 2009 | Acer Aspire 5100 Notebook
Keyboard and mouse pad on my laptop. Acer 5100 vista
On an Acer, the Fn key plus F7 will turn the touchpad on and off.
Try that to see if it works.
Mar 22, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Boots to Windows, but nothing works. No keyboard, no mouse, no usb or CD, no external monitor. I have an Aspire 5100 Acer Laptop that has no keyboard or mouse function period...
Try booting your computer from CD ROM with the OS CD/DVD already inserted and when prompted just try repair. If that does not work re-install the same on the same 'partition' assuming it to be C by deleting the the windows system files only. While doing so keep the internet on and immediately after the basic version of the OS is installed and the m/c boots-up for the first time, go to the official website and download the latest drivers for every component like toch-pad, keypad, display, audio, etc.(i.e. almost all the drivers)
Mar 16, 2009 | Acer Aspire 5100 Notebook
Keyboard and mouse pad not working accer 5100
try removing the battery and restart only using the mains lead. it worked on my aspire 5600
Nov 03, 2008 | Acer Aspire 5100 Notebook
Non responsive laptop
Try removing the memory/RAM. and if it has 2 sticks try just 1 in alternate slots.
Failing this the CPU may have overheated. Without CPU Function. No Processing is acheived.
Mike @ Compurepair.
Jul 22, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5100 model bl51
dear friend,
this is your system board fault
this is due to southbridge (ich4) or ATI (ixp460) dry sold damage.
you should change this ic to fix this.
go to the best repairing center near you.
Apr 09, 2008 | Acer Aspire 5100-5022 Notebook
Keyboard & mouse are dead
I just fixed this problem by doing the following:
Hard power-off (hold the power button until the laptop turns off)
Unplug the AC adaptor
Remove the battery
Plug in the AC adaptor
Hold ctrl and turn the power on. You should arrive at a black screen.
Hard power-off again, then turn the power on.
Nov 11, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 3000 keyboard failing
The problem is the battery as mentioned before. Disabling "Microsoft ACPI-Compliant Control Battery Method" should solve the problem of the keybord and the mouse, this is, because the driver dosen't work properly with a bad battery. I think it fires a lot of hard interruptions that are blocking the keybord and the mouse interruption to the system (each time a key is pressed an interruption is send to the processor... if the battery driver sends a lot of interruptions, the key interruptions don't have time to be processed in time - that explains the fact that the system responds to a key press is that bad)
Apr 06, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5100 Notebook Logo
192 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
