Configure new Zyair router
I am trying to configure the internal settings of my zyxel zyair router
    Novelist:
  • 101 Answers
Hi Dflori,
Try this site,
http://portforward.com/routers.htm
Scroll down to your Zyair, it lists several, click on it, and pick program you wan to work with. Good luck!
Posted on Jan 06, 2008
We have a Zyair B-3000 wireless network. With our older Notebooks (XP or Vista) the wireless communication is no problem but with newer computers I can't establish a wireless connection (e.g. HP Pavilion...
To trace the problem, I would first temporarily turn off security on the ZyAir B-3000 and see if you can connect with the iPad and the HP.
To do this login to the ZyAir. If you still have it set to factory settings you would login by clicking here: http://192.168.1.2 then type the password which is 1234. The find the wireless security screen and turn off WEP security. By the way, If you still have factory password, I would change that soon.
Here is the users manual with more details: ftp://ftp.zyxel.com/B-3000/user_guide/B-3000_3.50.pdf
After turning off all security, try and connect from the two systems that cannot connect. If you can then the problem most likely has something to do with wireless security. Now with the security still off try and connect with the other 2. If all 4 can connect without security turned on it is probably a wireless security issue. You could try changing from WEP to WPA security and see if all 4 can connect. You do not want to run your wireless router without security so make sure you turn the security back on..
I say most likely it is security, because maybe there are some settings that might be blocking the iPad and HP from connecting. Maybe the router is set to only allow two connections, or is set to allow specifc MAC addresses of the two older computers. Look around the configuration firmware in the ZyAir and see if there are any settings that would limit how many can connect wirelessly, or limit specific systems to specific MAC addresses.
After spending too much time on this and it still doesn't work, then you might consider doing a factory reset. Beware that a factory reset will wipe out all the configuration on the ZyAir and you will have to reconfigure. Instructions to factory reset are in the users manual link above, but basically you hold the side RESET button for 10 seconds, it will restart and you don't touch it till it is done resetting. If you do decide to do the factory reset, then right after resetting and before setting up security on the ZyAir I would try and connect all 4 systems at once. If that works then configure the ZyAir with security.
Dec 20, 2010 | Zyxel ZyAIR B-3000 (C46104) Wireless...
How to reset e zyair g-1000
On the Zyxel ZYAIR G-1000, the reset button is the small hole between the LAN socket and the power plug socket. Simply press this button for 10 seconds, until the link LED turns red. This will reset the unit to factory default settings.
Dec 01, 2010 | Zyxel ZYAIR G-1000 (91-005-026001)...
I have my zyair G-2000 wireless router connected to my home computer. Just bought a new laptop and want to use this router with it. How do I find the wep key for it to add to my laptop.
Connect a computer to a wired connection on the router. Point your browser at http://192.168.1.1/ That should take you to the admin interface of the router. If that doesn't work, check the documentation that came with your router --- it will give you the correct aaa.bbb.ccc.ddd (ip address).
May 20, 2010 | Zyxel ZyAIR G-2000 Wireless Router
Hi, i'd like to know how to reset the zyxel G5100, thanks . I forgot the password and i d like to reset it. It s the double access point.
You can RESET it with RESET button you can find RESET button in back side of router .
Press and hold it for 10 seconds so all settings are defaults.
Then you can access your router with default link http://192.168.1.1 or
http://192.168.0.1 then configure again and enable WEP security .
If you want more info about configuration of router check my trick on below link.
Click here
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 06, 2010 | Zyxel ZyAIR G-5100 (G5100) 802.11b/g...
Please help set up wireless for Zyxel Prestige 2000 router
Are you trying to set up the wireless router?
It is very simple.
Click Here for more info.
Oct 13, 2009 | Zyxel ZyAIR B-2000 Wireless Router
WEP key for ZyAir B-2000
go to the web page of the router default ip address is 192.168.1.1 and user name is admin and password is 1234. after then go to the wireless option in that seciurty option is there in that u get the wep in that you can get the password you change it that's all
May 05, 2009 | Zyxel ZyAIR B-2000 Wireless Router
Zyair b 3000 router blue light not working
i think your ZyAIR is not receiving power. so pls change the adapter of the devices
May 28, 2008 | Zyxel (ZYAIRB3000)
Sometimes wireles goes down unexpectly
OK often it's the XP Zero Configuration service, try disabling that and it may be better... also get the latest driver updates... Often just to disable and re-enable the wifi adapter sometimes in network connections, brings it back without a reboot too.
Jul 08, 2007 | Zyxel ZyAIR G-1000 802.11g/b (zyairg1000)...
Computers & Internet Logo
344 people viewed this question
Alun Cox
David Payne
David Payne
