Question about GE Profile WPRE6100G Top Load Washer
2 Answers drain but clicks instead...agitates and drains fine 110.92195110
Loud clicking noise only during the spin cycle. Unit won't spin but problem during the wash cycle..agitate fine. Took unit apart and the coupling units between motor and transmission (the two opposite plastic pieces that lock into the black coupler piece) look fine (not worn out). There does seem to be a plastic piece between the Brake and Drive tube and the Gearcase (the clutch assembly) that appears to be worn out. My parts book diagram that came with the unit doesn't show the piece that is actually installed in the unit. There is something called a Wahser, Spin Tube Thrust (ring) shown, but the piece in the unit doesn't look like what is shown...what is in the unit has plastic leg-like pieces not round and flat. Again, the unit only clicks during the spin cycle and doesn't spin.
I'm having the same issue with my hoover family 1300. Any ideas on that? would it be the same? mine is a front loader.
Posted on Jan 23, 2009
Not sur if you found your problem bu I found what was happening with my washer. I pulled the trans and motor assembly out and found a plastic gear / cam broken. I think the part number is 64194. it's found between the clutch and drive to the drum.
Posted on Mar 08, 2008
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
No drainage, Sound in Spin/Rinse Cycle
You may have a broken pump belt, or belt may have fell off pump pulley. Another possibility is that you have a bad clog before the pump keeping water from draining. Your machine will agitate because this is a separate belt. Good Luck Friend.
Oct 13, 2017 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Feb 28, 2009 | Washing Machines
Water does not drain, strange noise while in spin cycle
sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Apr 22, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Kenmore 110.92195110
those parts come as a complete kit. order a brake assembly.
Jan 06, 2008 | Kenmore 22422 Top Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
228 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
