Canon BubbleJet i560 InkJet Printer
Problem for Canon BubbleJet i560 InkJet Printer
How do you gain access to the "used ink tank" on the Canon i560?
By fayrankin12 on Nov 08, 2009
How do you gain access to the "used ink tank" on the Canon i560. I have tried the reset procedure for 5 Orange, 1 green flash as well as removing the print head.
How to access the "used ink tank" for the next step is not obvious to me.
Splain it like you're talking to a 67 year- old cause you are.
Thanks
Comments:
Nov 20, 2009
- If it is 5 Orange flashes and one green- this sissy solution will not work! Canon Sez:
Thank you for writing to Canon technical support. We value you as a
Canon customer and appreciate the opportunity to assist you. We
sincerely regret the light on your i560 printer continues to flash five
times.
When the Power light alternates between orange and green, the printer
was not able to initialize successfully. Five orange flashes indicates
the print head is not recognized, but does not mean the print head is
the cause.
For troubleshooting purposes, please perform and confirm the following:
1. Open and close the print head lock lever. There is no need to
remove the print head.
2. Make sure all ink cartridges are seated properly and evenly in the
printer.
3. Isolate the printer by powering off and disconnecting it from the
computer.
4. Check carefully for any objects or other material that may be inside
the printer or sheet feeder.
5. After waiting about thirty seconds, plug the printer in, power on
and see whether the printer initializes properly with a steady green
POWER light.
If the error continues, service regrettably appears necessary.
We would like to let you know about the Canon Loyalty Program. It is
designed to assist customer's that have a Canon product that is no
longer under warranty and requires service or parts, or for those
situations where the printer is not compatible with a new computer or
operating system. This program provides for a one-time purchase of a
new Canon printer at a discounted price. To aid in getting up and
running quickly, free next business day shipping is also provided if the
order is completed by 12:30 PM Eastern Time.
Solution #1
posted on Nov 08, 2009
Not Helpful)
greg_margo
Rank: Guru  Computer Hardware  Expert
Rating: 91%, 695 votes
Well Fay after much research, the best answers I've seen actually came from other experts on this website. The link below will take you to another Fixya page with several, very good solutions to the same problem you have. My personal favorite was soaking up waste ink from the pad with kleenex or some other absorbent material as you won't need to take apart your machine. You merely remove the ink cartridges and carriage to gain access to the pad/sponge that Canon calls it's waste tank. I do wish you well and hope you come back to let me know if you were able to fix your machine.
Greg
Fixya Waste Tank Solution for Canon Printers
Comments:
Nov 22, 2009
- The solution I provided was merely a "work around" for the error code you got. The only real solution is to repair the waste ink pad by replacing it which Canon recommends doing only a an authorized repair center. Sometimes, you can remove the pad (it's not a tank) and wash it out and allow it to dry. It's obvious to me the reply you got from Canon in that they want to sell you another printer. I'm sorry you feel my answer didn't solve your problem and I guess we'll just have to disagree whether it was worthy of the poor rating you gave. Good luck and I wish you well.
Greg
Was this helpful?
Yes
No
Popular Solutions for Canon BubbleJet i560 InkJet
Questions and Unsolved Problems for Canon BubbleJet i560 InkJet
Do you recommend Canon BubbleJet i560 InkJet Printer?
Answer
Answer
Printer will not print, center light keeps flashing, and we get a note on the computer that an error... (More)
Answer
vertical strips when printing a photo. Have already cleaned and alligned heads.
Answer
not printing black text- all ink cartridges are new everything has been cleaned- prints great in... (More)
Answer
Just put in put in new ink cartridges. However, will not print out in black. what should i do?
Answer
my i560 has worked ok for years , then message on screen printhead fault, could not find fault so... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon BubbleJet i560 InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
