Sony KP57WS510 Blinking 8 times
Hello: Our big screen just started doing this today. Puts itself in standby mode, red light blinks 8 times, pauses, ad blinks 8 times again repeatedly. What is it trying to tell us??!!! Thanks! Joanne
  • hippylsc Aug 14, 2008
    I have a set I bought in 2005 and after a while it will slowly become red then flash and go too stanby mode. the red power light will blink 8 times repeatedly. I called a rapair guy and he said the fix was so easy he didn't want to take my money, He gave me instruction to remove the front speaker cover and the particle board cover and see a screw that can be adjusted, well there was 6 screws with white paint marker on them, Being the mr. fix it guy I had to turn all the screw over a period of three day. Is there any sequence to get them back to default?
  • stang456 Dec 26, 2008
    Sony model KP-57WS510. Blinks eight times. Tried the screw adjusting still didn't seem to work. Any ideas? Is this too expensive of a fix? Thanks for the help
  • 211 Answers
You have a strt up problem. I found, in a similiar Sony Big Screen a couple of fixes. First thing to try is unplug the set from the wall for about 15 minutes and then plug it back in and retry the set. If this corrects the problem, I suggest you purchase a good ( Not a 5 dollar piece of junk) surge protector. ( One rated at 500-1500 joules. A good surge protector may prevent future processor lock ups. If this doesn't correct the problem, the problem lies in the circuit boards of the set. I found one problem in a Sony like you describe had a bad convergence chip and a burned resistor in the same board. Good Luck
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
Red flashes 6 times and pause for three secs
Using the remote, open the system menu and reset the tv.
Mar 07, 2015 | Sony Bravia Kdl-55ex500 55 Tv, Series Lcd...
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Oct 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Televison & Video Logo
1,103 people viewed this question
Top Televison & Video Experts
