Question about HP OfficeJet Pro k550 Printer
HP K550 blak print failure
New printer. Prints color test OK. Printed 1st couple of print test pages streaky. Performed print head cleaning a couple of times. Color seems OK but won't print any black. Burst of thick ink blockage?? Removed black cartridge and cleaned surface around outlet of tank and re-inserted. How do you get print nozzles to park on left side for access?
Press cancel button seven times, then it will clean itself.
Posted on Aug 29, 2008
Hold the far button on the right down for a minute and it will move the head over for access
Posted on Jan 11, 2008
My DSC38 printer is leaving streaky lines all over the printed sheets what do I need to change? thanks
If you have tried a new toner cartridge and that didn't fix it you probably need to put in a new drum or Fuser kit. If it is really old and has had a lot of use I would consider replacing the whole printer with a new one. The fuser kit I saw listed on Amazon for this printer was half the price of a newer printer. If you do a lot of printing or this is in a business environment make sure when looking at replacements that you get one rated for the number of pages you print a month. I have had really good luck with HP and Brother laser printers.
Mar 17, 2014 | DSC GESTETNER - DSc38u Color Printer
Mp960 color prints ok but black and white not printing
When was the last time you printed in color? New ink printers are built so with a "use it or lose it" theme. The print heads are now built into the machines and are not generally replaceable. Yours luckily is, but I don't know how easily. The link below is to the replacement which costs $130 + shipping. Sometimes it can be just as worth it to buy a new machine, in this case I would probably prefer to repair the damaged machine as the new printer cartridges cost more and have less ink.
Feb 16, 2010 | Canon PIXMA MP960 Printer
The printed pages are coming out really streaky. We have tried cleaning it, but no joy. Any advice?
Print a few pages. As they are printing open the cover. Remove the toner cartridge. Look down at the page that was being printed. If it is not "streaky" look at the fuser, it probably needs replacing.
If that page is "streaky" replace the toner cartridge.
Jan 22, 2010 | HP Color LaserJet 2600n Printer
Have new ink cartridges, however when I print a test page, nothing but the windows logo prints
You mean, the black color is completely absent from the printed page? Either the black cartridge is faulty and needs to be cleaned, or (less likely) the cartridge carriage is faulty.
Try running the "Printer Head Cleanup" routine from the printer manager maintenance menu.
Aug 28, 2009 | HP DeskJet 952c InkJet Printer
H/P C6180 black not printing
Had the same problem for weeks. Had to go thru all three levels of print head cleaning in the HP Toolbox menu to get black to work again. The head cleaning option on the printer itself was insufficient. Unless you've already gone thru all three cleaning levels this may be worth a try.
I walked thru the steps via the HP website FAQs for the 6180. Basically: Open the HP Solution Center, select Settings->Print Settings->Printer Toolbox, then click Clean the Printheads. After the first cleaning you'll be asked if the test page printed OK (mine didn't), click the Intermediate Cleaning box. You'll be asked again if the test page printed OK (mine did, but an independent MSWord print test was still streaky), click the clean again (sorry, don't remember what this one was called) for the third and deepest clean.
This last one worked for me, now it's back to normal printing. From what the HP website says I'm guessing that my black print head was dried up. That's a reasonable explanation for my situation, we had let the black sit dormant for a couple of weeks after the black cartridge ran out before we tried to install a replacement.
Hope this helps, sure was frustrating for me. Good luck.
Nov 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP K550 Prints Solid Gray Boxes Around Items
Hi drglass1 -
13,000 copies - that's awesome! although you've surely fixed this problem by now, for future refs or someone else searching for an answer... you might find this ref hp support helpful. happy printing!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00458018&lc=en&dlc=en&cc=us&lang=en&rule=35557&product=501369
Step 4: Clean the printheads
If the print quality is still bad, clean the printheads:
1. Make sure the printer is loaded with unused white paper.
2. Open the printer Toolbox and select the Printer Services tab.
3. Click Clean Printheads . A Clean Printheads window opens. Click Level 1 Clean .
4. Examine the page that prints for print defects.
a. If there are no defects, click Exit . Stop troubleshooting here .
b. If there are defects on the page, click Level 2 Clean . 5. Examine the page that prints for print defects.
b. If there are defects on the page, click Level 3 Clean . Note that Level 3 cleaning uses a lot of ink – it is not recommended if the cartridges are low on ink. - JW50
Sep 17, 2008 | HP OfficeJet Pro k550 Printer
Streaks / Bands of broken print area
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
HP OfficeJet Pro k550 Printer Logo
287 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
