Question about Honeywell Programmable Thermostat Heater
Honeywell thermostat RTH230B
The thermostat is not advancing through each program. It is stuck on program one, even though the time is changing on the thermostat.
  • 1 more comment
  • albaneseaj Feb 17, 2008
    The thermostat works fine in the heat program mode for all weekdays. On the weekend, it seems to get stuck in interval "3" regardless of the time of day. I've tried removing the batteries and reprogramming, advancing the clock and changing the progrom zones and nothing works. Any ideas?
  • Anonymous Feb 19, 2008
    I have a Honeywell RTH230B also and am now on my third one in less than 4 months. It has a tendency to "automatically" go into "hold" mode on its own when it is transferring from one program to the next. Then I hit the "mode" button to exit the "hold" mode into the correct program. Does anyone else have this problem? If so, what is the fix?
  • pas0826 Jan 19, 2009
    i want my thermostate to stay at 73 all day and night not using any program but my temps keep going from 78 down to 70 what the heck, i want 73 i just got this last week and am beginning to hate it what am i doing wrong,
    New Friend:
Sound like you need new one... take a look on amazon ecobee3 Smarter Wi Fi Thermostat Remote Sensor. It's not worth repairing it..
Posted on Dec 27, 2014
After several months of calling Honeywell (actually someone in India), I found what seems to be the solution. I think I became such a pest (they had a lot of complains from me in their record) that they put me on hold and called someone at Honeywell Corp. The solution was to "reset the microchip". You do this by holding down the "Mode" button and while holding it down, take the batteries out for a couple of seconds (still holding down the Mode button) and then put the batteries back in and release the Mode button. 10 days have passed and it has been working perfectly. Hope this doesn'f jinx it! Good luck.
Posted on Feb 26, 2008
  • rockingther Jul 06, 2010
    u can just take the batteries out and put them back in reverse polarity...IT WILL RESET!!....secondly..it also depends on the outside temp. if its more.. then their is the problem with the system not the thermostat......thirdly check with ur isu settings...........if u want more solution......mail me on [email protected]
  • dlmoore03031 Feb 25, 2011
    Thanks - you just saved me going out (in the sleet and snow - cue orchestra) to buy a replacement. Plus I now look like a genius in the eyes of the wife!
Ensure both your regular time setting and your programmed time settings have the correct AM/PM setting. If not, the displays will be different from what you think they should be.
If you're using the same programming for the entire week, ensure you've programmed it accordingly by pressing the "DAY" button for 3 sec. during the programming to include Sat.& Sun. Otherwise it will be default to a 5 day cycle.
Anytime you press the Mode button after you've exited the programming, it will revert to a "hold". This means you'll have to re-program to revert to program control---hit the exit button only once.
SOLUTION #1 worked for me - my time on the thermostat was correct, the wiring was correct, and my programming was fine, but the a/c wouldn't come on even though the temp was set to 70, it was already at 77!
BUT - you don't need to hold down MODE after you take the batteries out; what you should do is hold MODE when the take them out - LEAVE THE BATTERIES OUT FOR 20-30 MIN, so the thermostat completely loses all electricity - then hold MODE when you put the batteries back in; wait 5 min and it should work
Posted on Apr 06, 2009
    Sergeant:
  • 288 Answers
These new thermostat can be confusing to say the least. On yours does the display say HOLD on the screen? If so, then the program override is set, thus negating the program.
Posted on Jan 16, 2008
6ya staff
SOURCE:
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: http://yourhome.honeywell.com/en/faqs/thermostat . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see https://yourhome.honeywell.com/en/supportsearch#q=Rth230b . The direct link to the manual in English is https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
Heat not coming on. battery died.
Please go to the link and check graph "2.5 Installing the Batteries". Its really easy so it should be a piece of cake.https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf
Mar 30, 2014 | Honeywell RTH230B 5-2 Day Programmable...
Can thermostat stuck open on 2001 vw beetle affect automatic transmission performance?
No the thermostat would not have any thing to do with it not shifting properly,
Dec 04, 2012 | 2001 Volkswagen New Beetle
The furnace comes on @ 70* when programmed to be 60* at night
you have to switch it to settings and reprogram it. find your owners manual and it will tell you how to program your thermostat
Dec 01, 2012 | Honeywell Programmable Thermostat Heater
My thermostat is stuck on hold program at 82 degrees even whn I change is it goes back to 82.
Hello my name is Heath it will be my pleasure to assist you. The first thing you need to do is hit the run program button and this will get it off the hold function.
Sep 05, 2011 | Honeywell Programmable Thermostat Heater
I replaced the battery to honeywell RTH230B. Heat won't turn on.
I followed a comment from a previous source and reversed the polarity of the batteries. I then flipped them back to the correct position and the flashing battery indicator went away and the thermostat functions correctly.
Feb 04, 2010 | Honeywell RTH230B 5-2 Day Programmable...
I have a Honeywell programable RTH230B. I changed
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jan 08, 2010 | Honeywell Focus 6300B 5-2 Days...
Honeywell thermostat not lowering temperature
remove batteries let sit a few minutes reinstall.
if still bad replace they are not servicable
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
13,371 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
