Did you add a video card? If you have an AGP slot, it is best to put the video card in it. If so you need to go into the Device manager. Remove, disable or uninstall the onboard VGA driver. Go ahead and remove the PCI video card driver as well. Power down PC. Make sure monitor is hooked up to the Video Card, not onboard VGA. Power on PC. When Windows loads, it should detect the VGA card first, but if it detects the onboard first, ignore and don't setup onboard first. When Windows detects the card, load the necessary drivers when prompted. There is no need to reinstall the onboard driver for the video unless you wish to hook up two monitors.
there are two types ov problem
1,your desktop is agp but you insert pci express card
2,you didn't install a vga driver. GOT IT dude so out these things ok good luck........
Monitor flickers when starting up; flickering is particularly noticeable when streaming videos; and...
(More)
Monitor flickers when starting up; flickering is particularly noticeable when streaming videos; and there is a black boarder running on top of screen -- getting larger; chatted with HP -- suggested that a health check be performed on video card (loaded on motherboard) -- PASSED -- determined that it was a monitor malfunction and that I should purchase a new monitor (?; the monitor was purchased 12 mos ago (entire PC package) -- can this problem be repaired or should I indeed purchase a new monitor? Thank you.
Having the same "going black" problem with my HP w 1907 after about a year. Can anyone...
(More)
Having the same "going black" problem with my HP w 1907 after about a year. Can anyone tell me if they found it to be their computer or the monitor before I spend unnecessary money trying to figure it out.
My monitor won't connect to my chassis. I run a 9600GTX which has always worked when connected to...
(More)
My monitor won't connect to my chassis. I run a 9600GTX which has always worked when connected to the monitor. For seemingly no reason the monitor no longer accepts its signal. I've tried alternating between both open ports on the card and from DVI and VGA, but nothing yields a result.
