Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox tv my projection tv will work fine for a few minutes and the the screen becomes a trapezoid. the sides distort and get a sort of rainbow effect. the very center of the picture is the only thing uneffected. any words on the sides are sort of overlaid. at the same time the picture is sort of stretched.
  • coolfrog Jan 11, 2008
    The picture will work perfectly for a while then messes up. At other times it is right when I turn the tv on. Last night after a couple of hours it straitened up and worked fine until I turned it off. When it first started doing it, you could hit the side of the tv of stomp the floor and it would right itself. Will degaussing the screen help?
  • 152 Answers
Try degaussing the screen... if your tv doesnt have that option, here are some ways to achieve that
Posted on Jan 08, 2008
  • Asdrubal Perez Jan 11, 2008
    no.. there is a loose contact.. it may require some soldering.. i think that is a capacitor that is getting a bit on the loose, be careful when touching the crt.. otherwise you could get electrocuted.. even if its unplugged...
    you could still take the risk of doing it yourself.. but its better let someone with experience does this..
I have a 52 inch magnavox with rainbow colored distortion on the screen
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
Oct 28, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a 46" magnavox projection screen tv that has the red, blue, green colors on the left side of the screen when first turned on. After a few minutes of being on, the screen resumes to normal colors. ...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from
Sep 23, 2010 | Philips 60PP9352 60" Rear Projection...
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
When I turn the T.V. on The screen shrinks and becomes distorted. After it warms up It becomes more clear and works fine.
If your TV is shrinking and expanding you can get a repair kit from for less than 50.00
Comments: May 19, 2009- If your TV is shrinking and expanding you can get a repair kit from for less than 50.00 May 22, 2009- Here are the most common symptoms and example photos of this problem.
  • Video Shrinks and Expands - Over and Over - After warming up it typicaly works.
  • After a few weeks the shrinking stops and you loose all video and audio.
Its a fairly easy DIY job. Check the site
Their kits include a photo instruction guide, parts, email/phone support, etc.
Nov 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
Hi I have a sony KDP-57XBR2 television set and the
I had the same problem in blue. I took the right front speaker cover off (pops off) and the access panel on the right side 2 - 4 screws. In the upper right corner is a black plastic box with 2 rows of 3 adjustment screws. All I did was turn one of the "screen" screws (not the "focus" screws). Hope this helps. May only be a temporary fix, but good luck...
Aug 19, 2009 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arch
hi, you`ve lost your convergence ic`s, unless your very proficient at solder work I`d advise you call a tech, will require removing 2 large IC`s and possibly a few small support parts, resistors, chemical fuses etc. Every place is a little different but runs approx. 300.00 at my shop, gl, video-tek
Jun 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
I dropped my 27in phillps magnavox
if this is a distorted kind of rainbow aura affecting the colour, you need to de-gauss the screen - a good tv repair man will have the mains powered magnet to fix this - and shouldn't charge alot.
Feb 23, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
TV wont come on anymore
Common problem. Check the site They should have a kit to fix it.
Oct 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
Distorted picture
tv has red & blue converge problem,tried to fix it with remote by multipoint lining the t,s up didn,t help
Jan 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
117 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
