Question about Samsung HLP4663W 46" Rear Projection HDTV
Horizontal lines to nothing to blinking lights...
Hey, Thanks a lot for the help! Model HLP4663W: This is kinda of a long story but here's the issue. The set would be fine for about 45 minutes then it would start getting a lot of horizontal lines and colors across the screen. sometimes turning it off and back on would correct it for the rest of the day. But sometimes not. Also, when it was acting up, when I would turn to a different channel, there seemed like remnants of the previous channel still displaying. Not being a HDTV technician I assumed since the bulb was original it may need replacing. I ordered a new bulb from Samsung. As they are very simple to replace. Anyway, I replaced the bulb, then it wouldn't fire at all. I would get three blinking lights on the front power button, I took out the replacement bulb and returned it an put the original back in. Now the original wouldn't fire, and I get the three blinking lights on front for about 2 minutes, then it turns off. Thanks for the help! I really need it.
  • Anonymous Jan 09, 2008
    TV TURNS OFF BY ITSELF
  • Anonymous Jan 23, 2008
    Mine will have a green flash and then I'll either having scrolling horizontal lines or the screen will split and the top of the picture will be on the bottom and vice versa
  • 87 Answers
Did you put the door back on?
Posted on Jan 25, 2008
Sanyo tv st-21ms22b cant turn on with remote red light blink once and nothings happen.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
May 14, 2016 | Sanyo Televison & Video
My sony trinitron kv-36xbr800 screen clicks on when i press it but there isnt a picture only a blinking red light ,,help
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 24, 2015 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sound fine - no picture - no manual
Aug 26, 2015 | Televison & Video
Standby light was blinking once every 4 or 5 secs, now it has fizzled out and won't come on again. Thanks
Apr 14, 2015 | Televison & Video
Will not come on. light blinks 6 times
Hello
Six blinks denotes the absense of horizontal sweep. Check the horizontal output transistor, whcih can be located very near to the LOT [Line Output Transformer]; for short. If it is shorted, LOT must be suspected. Replace the line output transistor with a new one, and switch ON the tv for a short period of time, say 6 seconds or so, and check the heat of the replaced transistor. If it overheats within this time, be sure that LOT is damaged; shorted inside; and should be replaced with same type and number. If a digital multimeter which can measure frequency is available, take the frequency at the collector of the horizontal driver transistor. It should come around 15525Hz. If not replace the jungle IC. OK.
Jun 19, 2011 | Sony FD Trinitron KV-32HV600 32" TV
Try to turn on then green light then orange then blinking red and nothing can you help
Uh-oh. You have the YLOD. That can mean a lot of things. It's kinda like sonys version of RROD.
Jan 24, 2011 | Sony PlayStation® 3 (80GB) Console
My 36xbr800 blinks six times then pauses then blinks six times, this is repeated......
Check the voltage input to horizontal output transformer [LOT]. Check the voltage at the collector point of the line drive transistor. If the line drive transformer primary gets open this type of fault mau occur. Also check the frequency ant the collector point of line drive transistor and the base point of line output transistor. It should be aroung 15625 Hz.
Check and replace the horizontal output transistor if needy. Replacing it is better. The horizontal output is not working or a short in secondary power supply of SMPS or lot secondary, is your problem
Oct 14, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Standby light blinks and tv won't turn on
Four blinks = No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Dec 27, 2008 | Televison & Video
Color wheel or fan?
Sounds like the color wheel has shatterd, thats a fairly common problem with that model.
Jul 14, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
Jerry Greenberg
Jerry Greenberg
