Sony Grand WEGA KDF-42WE655 42 in. Rear Projection HDTV Television
Problem for Sony Grand WEGA KDF-42WE655 42 in. Rear Projection HDTV...
We had a storm the power shurge took the tv out
By atonyquin on Nov 08, 2009
we had a storm the power shurge took the tv out
Solution #1
posted on Nov 08, 2009
Not Rated)
SD Tech
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 97%, 879 votes
The place to start is with the ac fuse:
1-576-193-11 F1900 FUSE, 6.3A 125VF-1900 is its location number and it is a 6.3 amp fuse. The first number here is the SONY part number for this fuse--1-576-193-11.
You need to unplug the set and remove the back cover and follow the power cord into the set--it will lead you directly to the fuse--if it is bad do not buy one from RADIO SHACK--the fuse is somewhat special----I have seen GENERIC ones blow for no reason
Let me know what you find, I am here to help people,
Follow up and let me know what happens.
If this information has helped you, rate this solution as I do this here for free.
DO NOT HESITATE TO ASK MORE QUESTIONS FROM ME.!!!!
SD TECH
Was this helpful?
Yes
No
Popular Solutions for Sony Grand WEGA KDF-42WE655 42
Questions and Unsolved Problems for Sony Grand WEGA KDF-42WE655 42
Do you recommend Sony Grand WEGA KDF-42WE655 42 in. Rear Projection HDTV Television?
Answer
Answer
We have blue botches on the screen along with blue dots which are spreading. It is a WEGA... (More)
Answer
standby light flashes 50 times then lamp light flashes, no picture or sound
Answer
I just replaced my bulb, it works great for about 10 minutes, then shuts off again
Answer
i HAVE A BLUE BORDER ON THE RIGHT side of the screen and about 90% of the center is blue speckled -... (More)
Answer
television will not come on when turned on and red lamp light turns on.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Grand WEGA KDF-42WE655 42...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
