Question about Samsung RS2630SH Side by Side Refrigerator
Smell coming from the refrigerator
My refrigerator started making a noise about a month ago. It comes and goes. However it has started producing a smell like an overheated engine. The sides are heating up and the spaces in between the doors too have began to get hot. Anyone know what is causing this and is there a solution?
  • Anonymous Jan 16, 2009
    I have the exact same problem. I can hear something that sounds like a motor going out from time to time and other times I can smell the hot electronic smell and feel the inside edge of the doors around the seal is warm.
  • 211 Answers
I would assume you have a bad self defrosting motor. This motor generally is used to cycle heat at certain points to keep the unit from allowing the condansation from freezing inside the refridg. I am assuning the smell is this motor heating up. Should the motor quit, it is normally not a fire hazard but should be taken care of. You'll need to remove the back panel of the refridg and you'll see the minuture motor and probably hear is making noise. Always be sure to unplug the refridg before opening the back panel or any service to prevent shock. Good luck
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
Car smells like its burning
the bearing in the blower motor is going out causing the noise and the smell is coming from the blower motor. the parts house will give you the right blower motor for your vehicle make and model and engine size.
Jan 03, 2014 | Ford Cars & Trucks
Do not use ice maker and it makes noise
What is the complete model number of your unit?
Nov 25, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Brand new fridge. I have a bad smell like urine comming out from the bottom front. is this a leak.. fridge is staying cold. this smell started a week ago. Fridge is 2 months old
smell is urea,it is a gas produced when plastics get hot,it will go away in time,but also check the drain for a blockage (syringe with clorine bleach)and if fitted, wipe out the condensate pan with clorine
last make sure the door seals fit all round as iif not flush any condensate will drip out from the front bottom.
Aug 12, 2010 | Frigidaire Refrigerators
Refrigerator knocking noise
If it seems to be coming from underneath the unit it could be the compressor. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That's usually mounts inside the compressor. Usually when the compressor cuts off. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Any other noise would be from a fan. One in the freezer behind the back panel and one under the unit where the compressor is.
Dec 29, 2009 | GE Profile Stainless Bottom-Freezer...
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Noise from the right side of thr fridge
I would suspect something has come loose, like a panel screw somewhere. When the refrigerator turns on its cooling system, it may be causing the rattling, due to vibration of whatever has come loose.
Jul 11, 2008 | Samsung RS2630SH Side by Side Refrigerator
Buzzing sound for about 2 months
Compressor was replaced (also see additional comments made).
Mar 20, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Samsung RS2630SH Side by Side Refrigerator Logo
182 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
