Question about Samsung Digimax S630 Digital Camera
I cant put pictures onto computer?
Everytime i hook my USB cord into my computer,
it pops up saying "USB Device Not Recognized".
How Can i fix this?
: ) Cheers
  • 24 Answers
You have several options.
1. see first what operating system you computer runs.
if it is vista or mac, it will be recognized as unknown device,
look for SSCAM100 or DCIM folder. you will then see the camera files in that folder.
2. you should also download the cd driver, the cd that comes with the camera, to your PC. this will help the connection be proper.
3. if you're using desktop, try to connect the camera at the back of your tower. look for a USB port at the back of the tower and connect USB cord to it.
4. make sure you're using the proper USB cable, the cable that comes with the camera. for your S630, it is USB cable type 2.
5. also, make sure before you connect camera to PC, camera is turned off, when the USB cord is properly connected, that is the time camera should be turned on.
6. when unpluggin the camera to PC, make sure that you are safely removing the device from the PC so you will not have future connection problems.
hope my suggestions work for you.
Posted on Jan 11, 2008
I have a SimpleTech 1TB hard drive and I have alot of important documents on it. Everytime I plug it in a message comes up saying that the "Usb device is not recognized" I hooked it in a couple...
Let's try to get it recognized. I Presume you are using Windows... Make sure that your drive is connected and turned on. Go to your Control Panel, Then " Add Hardware". Just follow the prompts from there. To make sure it's recognized, go to your Desktop. Press "Start " and right-click " My Computer ". Now go to the last entry " Properties " , Then " Hardware " then " Device Manager ". If it still doesn't show them, I'll suggest you check your cables. Hope this helps. If so, don't forget to rate the answer please.
Jul 08, 2011 | Computers & Internet
My computer is saying my camera is not recognized
u need install the driver on 2 ur computer, if u have the cd that came in the box, then it use that or u can use a SD card reader to get ur pictures onto your computer
Mar 30, 2010 | Vivitar ViviCam 5022 Digital Camera
My camera won't be recognized when it's hooked up...
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
May 17, 2009 | Olympus FE3010 Digital Camera
Samsung eternity cant get pics onto computer
There was software that came with the eternity. Use it, or buy it off amazon.
Apr 19, 2009 | Samsung SCH-u550 Cellular Phone
When plugged into the computer my camera...
It could be (Cable, USB Port, or a driver problem)
try reinstalling the drivers & then use a high speed port (do not use USB hub or the USB's in the front side of your desktop), after connecting the camera, turn it on (make sure you have a fully charged battery
Feb 01, 2009 | Kodak EasyShare C613 Digital Camera
USB connect
insert the driver cd at the prompt of new hardware discover and install automatically as recommended by your computer
Dec 02, 2008 | Motorola Mobility RAZR V3
My computer wont recognize my mp3
I know this is only part of the solution:
- turn off your sansa clip
- put the slide button on hold
- press the centered button while connecting the sansa clip to your pc
the sansa clip will now be visible as a removable disk under 'my computer' :-)
I don't yet know how to proceed from here on
Sep 20, 2008 | SanDisk Sansa Clip MP3 Player
DIGITAL CAMERA C613
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 25, 2008 | Kodak EasyShare C613 Digital Camera
Won't install program onto my XP or Vista PC from my DCR-TRV140
did your video camera come with a cd to run on your computer???.......on some things you have to run the cd that comes with it before you are able to hook up your video camera and start uploading videos
Nov 25, 2007 | Sony Handycam DCR-TRV140 Digital Camcorder
I can no longer download the photos from my cybershot onto my pc
Plug the USB lead directly into the computer, not via a hub
Jun 05, 2017 | Sony Cybershot S650 Digital Camera
Samsung Digimax S630 Digital Camera Logo
122 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
