Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Toyostove Laser 56 EE 2 error
Ive checked the fuel, from what I could tell there is no water in the tank, It was working fine untill about 3 hours ago. The unit is brand new, less than a month old.
I ran the manuel cleaning cycle a few times, but still keep getting the EE2 error. The light starts blinking slow, then the post purge comes on and it throws the error.
Is this possibly a board problem?
  • 2 more comments
  • timhis Jan 08, 2008
    Yeah, it was under warentee, but I had to fight with the guy to repair it. Ill never do buisnes with this local company again.
    Turned out like most of the post it was the flame rod. And he said the carborator was full of trash already, but I dont see how that is possible. The filter on the tank and the screen in the pump were spotless. Probably just blowing smoke, to make me think he did more than he had to do.
    Also he said if the unit wasnt completely level it could cause problems as well, he said not to go by the plumb bob on the side, but to instead use a bubble level and make sure it was square all the way around.
    Hope this helps anyone else that may be having issues with their heaters.
    Tim
  • bob macconnell Feb 13, 2009
    my laser 56 has same problem ... and flame rod was replaced ... how can i check to see if the problem is the pump rf if its the circuit board ... ? brrr cold ......the stove works intermittently .... but only on manual and only occasionally ....Chilly...
    same problem laser 56 , altho when flame rod was replaced ,, stove burned better but shut off... ee2 . and pump is def not pumping ... is it a pump or board problem /?
  • bob macconnell May 11, 2010
    lea ...the stove was bought second hand ,,, so no warranty ... the flame rod was replaced as the ceramic was cracked...the burner mat was replaced as the legs were somehow bent. my experienced service man said altho the tank was NOT 16 in above ..i should still have good oil run , esp as the tank is full (100 gal tank). when the copperline @ the burner pot was removed and stove turned on , no fuel was seen coming out ..so we are thinking a bad connection ( as the stove does work intermittently ///// and if this is not the soln ,, then it must be the circuit board perhaps ,, All of your suggestions were right on the $$.,... i do wish your in my back yard ....thanks tim leo and tom!!
    Novelist:
  • 126 Answers
Tim,
I have been working on Toyo's for 14 years now. During this time I have never seen a flame rod that was bad except ones that people have broken themselves. The rod is just a piece of heavy wire that is insulated against the pot. It is almost impossible to mess it up. Now, that being said, you can have a problem with the flame rod being dirty or sooted. Since your stove is so new I would look at the fuel system. If it is clean I would go after the burner mat. There have been mats lately on new stoves that have caused them to soot up. When this happens the flame rod gets covered with soot and gives the EE2 message. A new stove that has a burner mat problem would be covered by the warranty. Bad fuel that causes a problem will not be covered. The other thing that is not covered is a stove that has had an iced up the exhaust pipe. A good dealer should be able to help you get the stove going and explain the warranty.
Tom Hawkins
hawkins111@gci.net
Posted on Feb 13, 2009
  • Thomas Hawkins Feb 13, 2009
    Chilly,
    It is unlikely the fuel pump is your problem. You did say the stove works once in a while. If the pump is the problem it will never work. The main board is another bullet proof system and probably not the problem. I would go after the fuel system. Clean filter, enough fuel, clean filter on stove and a tank that is high enough to provide the proper head (bottom of tank 16" above the floor your stove is on). If you want to prove the fuel pump, remove the copper line at the burner pot and put something under the line. Try to start the stove. Once the Med or Low light comes on you should have some fuel dripping out the line. If there is not fuel dripping and you have a thumping noise, you have a fuel system problem. No fuel and no thumping you have a fuel pump or circuit board problem.
    Keep us posted
    Tom Hawkins
    hawkins111@gci.net
I have no power to my fuel pump i think its the board
Posted on Jan 01, 2010
I have finally found the problem with my laser 56 is the circuit board , after having taken it to a shop for monitoring .,...and replacing the fuel pump .. ,flame rod , etc ,,,,before replacing the board , however im goin to have a friend (mr fix-it) have a look at it and see if he can determine if it has to be replaced or whatever ....anyone know any of the specs for the circuit board ,,,, ?
Posted on Apr 09, 2009
    Master:
  • 619 Answers
Hi your toyostove is under guarantee if let sombody repair on it , the guarantee will cancelled , try to call renai on line
Posted on Jan 08, 2008
I have a toyostove laser 56 that blowback exhaust during windy days. Is there an easy fix? Tom
Three times recently I got the EE 2 error. Each time gunk had built up where the tube goes into the firebox. A delicate scraping with a wire solved the problem. Now, what causes the gunk to build up?
Feb 27, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
I let my tank empty before refueling and now my toyo laser 56 has a ee 2 error on it how can i fix this?
You should check the filter at your oil barrel if you have one there and loosen the small vent screw to bleed the filter and line. You can also check the strainer in the fuel sump but remember to turn off the fuel at the barrel before removing the strainer from the sump. Also press the float reset button on the full sump. You can loosen but not remove the fuel line on the back of the heater if needed to get the fuel flowing. Be sure to place something under it to catch the kerosene and have some rags handy.
Jan 03, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
Reading says EE 2 what does this mean
Hi Sandra, EE 2 means that the heater did not ignite. There could be several causes. First let me ask, did the heater make a ticking or thumping sound before you got the EE 2? If so that means the fuel isn't getting to the fuel sump. It could be caused by an air bubble in the fuel line, a clogged filter at the tank (if you use an outside tank), or a clogged fuel strainer in the fuel sump. EE 2 could also be caused by a bad igniter. Did the heater light at all? If it did then the igniter is good. If it didn't the easiest way I have found to check the igniter is to use a clamp on ammeter or use a multimeter to check the resistance of the igniter. Another cause is a dirty flame rod. If the heater lit then went out I would suspect this. It can be cleaned with some steelwool or fine sandpaper. Let me know what you find or if you need more info.
Oct 04, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
I have an error EE 2 on my lazer 56 toyostove Does anyone know what that means?
EE 2 means its not getting fuel, your flame sensor could be dirty, or there could be a problem with the circuit board. The heater goes thru a 3 min warm-up/purge before the pump comes on. If the pump is making a loud ticking sound then it isn't getting fuel. You should then check your filter and the strainer in the fuel sump. If the pump isn't making a noise you could check the flame rod and clean it with some steel wool. You should check to make sure the igniter is working also. After you turn your heater on the cover on the igniter will start to get warm and will get very hot before the purge is done so use caution. Hope this helps.
Apr 03, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Getting code EE 2 on a laser 73 toyostove that runs on kerosene
EE 2 usually has to do with the fuel. Does the heater make a loud ticking or thumping sound? That's the sound the fuel pump makes when its not getting any fuel. Check your filter, check the strainer in the fuel sump. Depending on how cold it is any water in the fuel line could be frozen blocking the fuel flow. You might also check the flame rod for soot. It can be cleaned with some steel wool.(nitensheaterservice@embarqmail.com)
Jan 12, 2010 | Rinnai Toyostove Direct Vent Heater:...
Fuel Line Error code
Could be water in your barrel. Did you replace the filter? It can freeze and block the fuel flow. Check the strainer in the fuel sump. Is your code EE 6 or EE 2. Depending on the code you may need to clean the flame rod.
Jan 11, 2010 | Rinnai Toyostove Direct Vent Heater:...
Heater keeps shuting down and displaying EE 6
Check for air leaks in the fuel line. Push the red reset button only once. It's usually a fuel problem. Contamination, air, mixed fuel.
Nov 26, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Laser 56 EE6
EE 6 happens for several reasons. Most likely in your case when the stove runs for a while after you turn it back on, the code is due to and over heat. The circulating fan and cover need to be spotless. If they are then the code is due to low fuel, no fuel or dirty filte on tankor stove.
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Jan 09, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 73 heater with a EE 2 error
replace the flame rod. or it could be the computer board for the flame rod. flame rod detects the presence of a flame.
Dec 01, 2007 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Oct 20, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
2,373 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
