Question about GE Energy Star WCVH6260F Front Load Washer
My washer keeps on stopping in the middle of the spin cycle
When it gets to the spin cycle it cuts off and begins to make a hum noise and no spin. I have opened the front panel and turned the white knob and emptied out all the water and any other items but it still is not running through a complete load or spinning. Please help my clothes are starting to mold.
Take the lower front cover off, 3 screws on bottom.
Put bucket under right side, large round piece.
Unscrew large white round piece, dump change and lint out and put back together. I did it today.
Posted on Jan 20, 2008
    Sergeant:
  • 264 Answers
You will need to get some help to put the machine near your back door so that you can put the gray hose out side the door when all water is gone your door should open if not then you need to take your pump out and clean it out and then take the filter out it might have a sock or some thing clean it out and buy the time you have put it all back the door should of opened take any thing out of the drum put the machine back and put it on a program so some water can get in the machine then or put it on a rise and spin that will be a good program to put it on if the machine finnish then its all done.
Posted on Jan 06, 2008
My frigidaire LTF6700FSO will not spin
Your symptom sounds like a jammed drain pump. Was it spinning and then stopped before the spin cycle should have ended or did it not begin spinning when it should have?
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
Our whirlpool top loading washer starts making a high pitched whirring noise in the beginning of the first spin cycle. Once it gets going full speed the noise stops. What could be?
If you can hear the motor humming during the spin cycle, it could signal a defective motor drive. It's possible for the motor to fail in just one direction, which may be why you only hear it some times.
This kind of issue often requires the help of a professional. To learn more about this issue, read Washing machine will not spin but will pump and agitate. I hope this helps.
Sep 12, 2012 | Whirlpool Washing Machines
Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Jun 06, 2009 | Washing Machines
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
May 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
172 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
