Question about Samsung TXN3075WHF 30" TV
Bad picture Wavy picture and bowing on edges.
    Novelist:
    Champion:
  • 211 Answers
Hi Dan,
It sounds as if you have a bad filter capacitor in your power supply. Check the main filter caps rated at 150 volts and above. It's likely one is leaking and need immediate attention. I hope this helped. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
53" rca model p52754at
CRT pictures that "bow-in" on the edges usually indicates that the high voltage power supply is failing.
Dec 03, 2010 | Televison & Video
I have a Philips 60PP9202 60 in. Rear Projection HDTV-Ready Television. I do not have a remote for it, which I am going to purchase ASAP. When I press the up/down channel button on the TV it changes the...
Ur tv have a convergence problems.Ur convergence board the two convergence ICS,and some or all it resistors are dead.U know how to solders?U have soldering tools,and solders.Tries Websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 10, 2010 | Philips 60PP9202 60" Rear Projection...
The picture is bowed and has a rainbow affect around the edges
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 01, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Bowed picture and color misalignment
Replace both STKS ICs Ck low ohm resistors 2.7ohms most of the time there will be 2 of them bad.
Jun 11, 2009 | Samsung HCN5527W 55" Rear Projection...
Hi, have a 50 inch rear projection Mitsubishi. The problem is that the picture is curved and some of the words around the edges are doubled. Its most noticeable when watching sports because the score board...
power transistors in the convergence circuits on this series TV go bad after several years, making the wavy lines around the edge of the screen and 'doubling' of the edges of the text in varied colors which do not converge. Professional repair is required unless you are brave enough to tackle the project yourself and follow some rather simple instructions, buy a few tools from Radio Shack, and save yourself about $500 bucks...which I did on my own 42" Panasonic rear projection set.
Feb 01, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Sony KP-53HS10 - Green & pink halos & picture "bowed" on edges
you will need to replace the convergence IC's and test resistors on them for bad values , if you want to do the repair yourself
otherwise to have a tech come out and do the repair will be about $300
Dec 12, 2008 | Sony KP-53HS10 TV
Goofy intermitent picture (bows with wiggly fibers across screen)
Convergence amps are going bad replace these and you will fix your intermittent problem.
josh
Mar 02, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 10, 2007 | Samsung PCL6215R 62" Rear Projection...
Mitsubishi vs 60719 - Wavy bow in picture
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Jan 28, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Samsung TXN3075WHF 30" TV Logo
119 people viewed this question
Jerry Greenberg
Jerry Greenberg
