True TD-50-18 Beverage Cooler
Problem for True TD-50-18 Beverage Cooler
I own a true 2 keg beer cooler and it has recenty
By kcwolf3 on Nov 08, 2009
I own a true 2 keg beer cooler and it has recenty been not able to turn off the cooler and freezes the beer. is this a problem with the thermostat or something else?
Solution #1
posted on Nov 08, 2009
Not Rated)
mitch_01
Rank: Guru  Refrigerators  Expert
Rating: 88%, 18 votes
This is probably the thermostat stuck closed and bad. Turn the tstat all the way to left or counter clock wise. The compressor should turn off.If the compressor continues to run the tstat is stuck and bad. A good replacement tstat would be Ranco # A12-1560.
Was this helpful?
Yes
No
Popular Solutions for True TD-50-18 Beverage Cooler
Questions and Unsolved Problems for True TD-50-18 Beverage Cooler
Do you recommend True TD-50-18 Beverage Cooler?
Answer
Answer
beverage well is filling up with condensation water
Answer
does this model have a drip pan? if not how does it drain and to what? right now it is draining onto... (More)
Answer
I went to retrieve a bottle from the cooler this evening and they are barely less than room... (More)
Answer
we purchased a used true double door cooler and found that the doors don't slide shut tight enough... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
