The fan speed in my mini split a/c indoor unit is abnormaly low even when set in High speed mode. This unit also has a powerful mode to raise the speed beyond High for 15 minutes, but it is not working either. I replaced the fan motor, the power supply board and the main board to no avail. Any help will be appreciated.
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a...
(More)
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a forced air system. Recommendations from heating contractors include Trane, SlantFin and Weil-McLain. Are these the best choices?
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at...
(More)
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at the lowest price. We stand by and guarantee the quality of our laptop battery.
<a href=http://www.bestlaptopbattery.co.uk/hp/dv1000.htm>Hp dv1000 battery</a>
Our Price: At Bestlaptopbattery.co.uk, you always pay the lowest price. We make this sure by offering our Best Price Guarantee on all our Hp dv1000 laptop battery.
Our Service: We have a dedicated team of customer service executives who are eager to help you save time and money by sharing their knowledge and expertise on batteries and related products.
Your Satisfaction: Your absolute satisfaction is our top objective. We stand by the quality of our battery and offer a 30-day money-back guarantee on all our products, no questions asked. Our products also carry a 12-month full repair or replacement warranty for any form of manufacturing defects.
How can you care Hp dv1000 laptop battery to get the maximum life out of it?
It is a question we frequently asked. It's a valid question since laptop batteries are usually expensive to replace.
First of all, how long should your battery last? 2-4 years is generally acceptable depending on how frequently you use and charge the battery. If you travel a lot and use and charge your battery frequently then you might only get a couple of years at the most out of your laptop battery.
The Hp dv1000 laptop battery are usually made with Li-Ion laptop batteries and the very nature of Li-Ion batteries is that they have about 500-600 charges and last at most about 4-5 years (shelf life). They also have a self-discharge rate of about 1% per day so you need to be sure to charge them at least every 6 months.
I have been give a DL Window-type Air Conditioner Model is DW-15/E and I can't seem to locate where...
(More)
I have been give a DL Window-type Air Conditioner Model is DW-15/E and I can't seem to locate where the drainage point is? Could you also please let me know if there is any special install instructions or helpful hints that will make installation easier?
With my RA-05MA Aircon unit came a piece of Black PU Foam about 2"x14"x10" with cuts...
(More)
With my RA-05MA Aircon unit came a piece of Black PU Foam about 2"x14"x10" with cuts in it. Is that for putting around the outside, just to seal the gap when fitted?
Fujitsu inverter. Worked fine, then manual only, now nothing. Have changed batteries and tried...
(More)
Fujitsu inverter. Worked fine, then manual only, now nothing. Have changed batteries and tried unverisal remote.
