Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
SONY WEGA TRINITRON
TIMER LIGHT BLINKS AND THEN TURNS OFF BUT TV DOES NOT TURN ON. ANY RESOLUTION WOULD BE GREATLY APPRECIATED. IT SOUNDS LIKE IT WANTS TO TURN ON BUT WONT.
  • 1 more comment
  • Anonymous Jan 25, 2008
    Same problem with same make and model TV. Mine is less than 5 years old. Any ideas on what to do?
  • stanley413 Feb 02, 2008
    Went to standby mode automaticall and screen went black. It will not start up again. When its turned on you here some swicthes clicking, but thats as far as it gets. the blinking standby light blins 7 times and pause, then 7 times and pause.
  • Anonymous Feb 12, 2008
    My set is 10 yrs old. Not one problem til now. Light blinks and sonmetimes will get a picture after along time.
  • 2,042 Answers
Power cord disconnect cable overnight try next morning power bar to not good for life especialy if you got lot off stuff on it cheers
Posted on Jan 17, 2008
6ya staff
SOURCE:
Hi my tv seems to be on standby/timer and will not come back on how do i get this problem fixed
It sounds that there is no communication with IIC bus with other ICs. Check whether the standby light blinks when you turn ON the TV by its Power Switch at it front panel. If blinks, count the number of blinks. Check this for more details about the blinking codes to Sony Wega TVs. If it does not blinks, make sure that the main system control IC has the fault.
Jan 02, 2013 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My Sony trinitron model number kv32hs500 blinks 6 times then turns off. It worked last night but now it won't. Anyone know why? I realty can't afford a new tv so any advice on how to solve this problem...
an ic must be replaced the number mcz3001d
there are 2 , one in the powersupply, one near the flyback tranformer, mostly this one goes defect.
when you heat it up with an hairdryer it will work again
Apr 08, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My Sony Wega KV-36FV27 TV will not turn on
My sony wega trinitron will not turn on, it just clicks when i ush the power button an blinks on standby/timer
Dec 11, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Tv doesnt turn on
use a blow dryer to the back were vents are and remove humidity and or dust
Sep 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Timer button blinks but doesn't turn on
There are several faults that can cause this. Shorted diodes in the high voltage, a bad flyback transformer, a shorted CRT driver IC. None of them are very easy to fix.
Mar 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv27 s42 trinitron color tv
your tv has a problem inside..the supply that is going to the tube was been cut out... only the servicemen can do fixing your tv... there is a deefective parts...
Sep 18, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
SONY WEGA TRINITRON
THE TV SEEMS HAVE A TROUBLE ON DEFLECTION CIRCUITS
I DO NOT KNOW IF YOU TRY TO DISCONNECT WII , BUT I THINK  THE PROBLEM
WILL BE THERE ALSO. - DELFO
Jan 06, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
100 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
