Question about Amana ALW480DA Top Load Washer
Amana washing machine LW4203W2 MODEL
Trying to put on the belt the belt is a just a little to big is there an ajusting for the belt or maybe the wrong belt. not sure if its on right
  • 57 Answers
Make sure you have the right belt because there are 2 belts for the machines if your motor mounts to the tub or if it mounts to the bottom of the washer and make sure the belt is on the tensioner
Posted on Feb 16, 2008
6ya staff
SOURCE:
Belt off how do you put it on?
This washer does not run by belt drive, it has a direct inverted drive motor with a motor coupler between the motor and the transmission, if you need assistance on how to replace the motor coupler please comment back. If you can see a belt under the washer than you have listed the wrong model as your washer.
Mar 10, 2013 | Amana 3.2 cu. ft. Top-Load Washer
My belet went out
What is the model number?
Oct 16, 2012 | Amana Washing Machines
Amana washing machine,model# alw480dac,serial#15950607at. drive belt starts smoking during spin cycle.machine worked fine three years ago then was put in storage.I would appreciate any with this...
it might be that the gearcase stiffened a little since it was not in use for so long, try to spray WD-40 on the bottom of the gearcase while it spins that might help
Sep 05, 2011 | Amana Washing Machines
Tighten the belt on an Amana washer?
The belt should already be pretty tight after wrapping around the barrel and the motor pulley. The belt may be worn and should be inspected and probably replaced.
To prevent similar problems in the future I suggest you be aware of how big of a load you put in the washer.
Mar 13, 2010 | Amana 3.2 cu. ft. Top-Load Washer
HOW TO REPLACE A BELT ON AN AMANA LWA65AW wash machine
FIRST DISCONECT FROM POWER AND THEN REMOVE ALL SCREWS HOLDING MACHINE PANELS IN PLACE , LOCATE BELT TIGHTINER LOOSEN AND REMOVE OLD BELT , THEN FIT NEW BELT AND AJUST TENSION .
Nov 01, 2009 | Washing Machines
On my direct drive model number DLW330RAW how do I get the belt back on around the pump pulley?
use a screwdriver. put on the small pulley first - then the big one.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Amana Washing Machines
How to put on a new belt for Amana washer model #LWA50AW
I just did this today. You have to remove the motor. first start by removing the two hoses then remove the four 1/2 inch bolts that hold the motor/pump assembly. the wires are clippes to a bracket, pry that off removr the whole motor assemly with the bracket by pushing on the tub to manipulate it out. Then remove the three #25 torx screws that hold the pump to motor, remove the pump then route the belt onto the pulley around the inside pump mount put the motor back on the reinstall it the way you took it off. its not that bad (for the first time ever working on a wash machine). I hope you dont have the problem I do, the belt slips in the spin mode - that is probably why the belt failed in the first place I am still trying to find a solution to that. if you just have a failed belt, you will be just fine.
Apr 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Fitting new drive belt to tricity bendix aw405
most have no ajustment little tip put belt round the largest wheel then on the motor spindle put a flat blade screwdriver and leaver the belt on if you can turn the drum this helps
Oct 06, 2008 | Washing Machines
Amana ALW480DA Top Load Washer Logo
121 people viewed this question
Top Amana Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
