Garmin StreetPilot c550 GPS Receiver
Can't find State or Province
posted by CoachPoly on Jan 06, 2008
Ever, since I updated my Garmin C550 using the Map update 2008" when I now select "Where to?" and then "Address" and use the prompt for "Spell State/Province" I get the normal <Enter State/Province> box to spell out the state. Normally I type in something like CA or just C and a list will come up. However now nothing is found even after I've spelled out the full state name. I have all the newest software by way of the webupdater. Everything else seems to function 100% to include other icon based look-ups like "Food, Hotels...
I have two C550's both with the same exact version updates and their own product key map updates on works and one doesn't. What's wrong?
Please excuse my question - because I answered it altready. After reloading "Map Update 2008" a third time it now functions. I wanted to leave the question here in case someone else has had this issue and they also thought about reloading the Map.
In my case reloading the 2008 MAPs did eventually work. It wasn't until I was about to try for the 3rd time I realized it may be my PC (yeah right that's what Tech Support allways go to first). They would have been right, my second C550 updated just fine using a newer PC with faster 2.0 USB's so I used it for my first C550 as well. Bingo! I don't know if it was just coincidence and the 3rd attempt was going to work anyhow or if the 2.0 USB did really make a difference. Does it?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 18, 2008
Thanks for Trying (70)
audiqv8
Rank:Guru Guru
Rating: 88%, 245 votes
The C550 does support USB 2.0 so data transfer of the Maps was most likely faster. The newer USB drivers from Garmin is most likely USB 2.0 compliant. Perhaps they didn't fully test it for USB 1.1 Anyway it's working for now. Usually I go to setting Map, Map info to verify that the upgrade was successful.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Can't find State or Province:
I don't want to Accept this solution
Can you Help with these GPS Devices problems?
battery wont charge charger ok battery ok
My new c550's battery life seems to be about 2 hours. When...
i dont now what i did now i have pin cod on my pc i dont...
hi ## i v got a nokia n95 8gb mobile phone locked to...
the garmin battery ran out. it is not recharged but not...
Loading problems.
Repair Service
Find GPS Device Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
