Screen I am in need of a new plastic screen for our tv. The screen was accidently bumped and there is a small opening on the plastic screen. I need to know how much it would be to replace the plastic screen. I need a screen for my Hitachi. Ive been googleing my head off. The only advice I got from truelove was a motto : dont give up: not any help at all.
  • 1 more comment
  • luvnnurse Jan 06, 2008
    thanks for thats helpful, now could you kindly tell me where to find the part number for the screen? Heres everything I kow about the television. Hitachi 50VG825 projection technology LCD compatible tech. HDTV aspect ratio 16:9 video system NTSC max resolution 1280x720
    This morning it made a sound like a bunch of glass falling.Don't know if this will help but figured it wouldn't hurt to mention it
    Now that you said it , it did sound like a big mirrow. As soon as I took the screws out for the frame the glass fell.The plastic looks fine,thanks for everthing. Where coould I get one of those books? Man you made joining the premium package worth every cent!!!!!!!!
    Genius:
  • 1,153 Answers
Thanks for that! Don't give up is right!!!
Ok Since you have a Hitachi and I don't know the model, you can click on this link www.vancebaldwin.com and find the electronic component area and find the Name brand click then look for your model. I would be happy to help if you can not find it. Let me know!
Thanks
Truelove(Ok by me!)
Posted on Jan 06, 2008
  • Lashawn Robinson Jan 06, 2008
    Didn't know it was a LCD, how bad is it, I'm still looking!
    Ok don't know if this good news or not, you mention that you heard glass falling, this maybe the mirror inside broken. My book tells me that the first is : Part# KR03244 which is LC58 Screen Assy. 50 the price is $362.47 and Mirror Part# KS08931- LC4x PF50(A) at $112.71. You can call 1800-844-7871 and ask if they have one or search around and shop for less. You can try MCM electronics. Tritronic.com, Bluestar-online.com etc. Hope this helps again!
6ya staff
SOURCE:
My sharp 32c540 picture is dark since i bought it brand new 6 years ago.
You may just have to make a different kind of adjustment.
This is what is called a direct view or crt type TV.
Inside on the main board (see attached photo) is the "flyback" transformer.
Note the two little controls embedded in it----top one is focus--leave it alone.
Lower one is SCREEN and a very slight upwards or right adjustment will bring the overall brightness up.
You want to adjust it just till with brightness on set all the way up you have a normal picture.
Too much and you get excessive brightness and trace lines and or further too much shuts set off.
Some sets have two holes in back of cabinet and small tool can get in and adjust the LOWER or screen control and others the back has to be removed.
Lay set face down on padded surface, remove back screws and set upright---do not touch anything inside with set on when you make the adjustment--control is plastic and a plastic tool a good idea--I have used regular screwdriver but know what not to do.
Let me know if you have questions 98% chance just need the Master Screen bumped up a little bit.
Mar 11, 2012 | Televison & Video
My mirror is cracked on my toshiba 46hm84. How Do I replace it myself
Here is a picture of the front bezel removal to get access to the mirror.d11d1b4.jpg
Sep 19, 2008 | Televison & Video
Dropped iphone screen cracked line across bottom of screen will not unlock now
You must change screen and digitizer. This will cost about 70$ if you open it by yourself.
If you open it up:
1. You need small screwdriver
2. Suction cup, smaller the better.
3. Small "sharp" object possibly plastic if you have.
4. Now start by opening the 2 screws bottom of the phone.
5. Use suction cup on the screen AND SLOWLY AND CAREFULLY lift it up.
6. There are connectors (flexes) you must use small object to get those open.
7 Now the screen and digitizer is out.
8. Start going back and put the new digitizer in place. Remember to put those flexes back on.
Hope it helps.
May 26, 2011 | Apple iPhone Smartphone
I think the inside panel is cracked
Yes lcd screen is cracked. No way to repair, other than changing screen. Cheaper to buy new tv.
Jul 20, 2009 | Vizio L32 32 in. LCD HDTV
TV attacked by hard plastic shark
I'm sorry to say that once the screen is broken due to those accidents, there is no way to fix the screen. Is time to buy another TV at this point because the screen repair it could even be more expensive then the new TV.
Jun 03, 2008 | Panasonic TC-32LX20 32 in. HD-Ready LCD...
I wnat to replace the screen
Hi there. If you just want to replace the plastic cover on the phone which is on top of the lcd screen then get a small screw driver and lift off the plastic from the top where the ear piece is situated. The plastic cover will lift of quite easily and you then just replace the clear cover with a new one. Make sure that you are in a dust free area so that no dust is trapped between the plastic screen and the lcd screen. You should be able to buy the plastic screen covers from ebay for under £5.
Hope that helps.
Gary
Apr 03, 2008 | Cell Phones
Thick plastic film covering glass screen got deeply scratched while moving
Hi there!
I would simply replace the plastic sheeting. Will certainly be cheaper than replacing a tube. Glass tvs don't normally come with this plastic so leave it off if you can remove it. There is a type of spray on the market for this purpose, just don't know if available in your country. Please note: It is dangerous to use a tv which had been scratched beyond 1.5mm, The glass may become unstable and implode if bumped by accident. Good Luck,JUS004
Mar 08, 2008 | JVC AV-32FA44 32" TV
42HP66 - Cracked the Glass plasma screen
It is worthless. The glass itself is the sealed plasma display unit. once it is cracked it will not work correctly. The most expensive part of the set.
C-Dog
Feb 13, 2008 | Toshiba 42HP66 42 in. LCD Television
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
