Home | Rinnai | RHFE-1004FA 38,400 BTU Energy Saver Duc... | Getting an error code
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Problem for Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater...
By allanmcdonal on Nov 08, 2009
Getting an error code "11" on display
Solution #1
posted on Nov 08, 2009
Not Rated)
Therinnaiguy
Rank: Guru  Air Conditioners  Expert
Rating: 88%, 394 votes
Gas issue, check your gas supply to the heater. If the unit has been sitting a while, you may have debris in the burner. Spiders and mud wasps love the smell of gas and nest inside unused heaters blocking the gas. Check your exhaust vent for obstruction. If you can, open the front of the heater by removing the two top screws on top right and left sides of heater, and unplug the light as the panel opens. You will find two small rectangular pieces of metal held on the heater with one screw each. Take these off and it will have a small window you will be able to see inside the heater. Cycle the heater and look for blue flame between the two windows. If you don't get any but you hear clicking coming from the top right side of the heater, you have an obstruction or the igniter is not sparking. Check all the wires behind the plastic on the front of the heat exchanger and follow them back to the circuit board and check there. If you get flame but goes out in a second or two, the flame rod is dirty or bad and you will need a technician who is familiar with the Rinnai. Best I can do without being there! Good luck>
Was this helpful?
Yes
No
Popular Solutions for Rinnai RHFE-1004FA 38,400 BTU
Questions and Unsolved Problems for Rinnai RHFE-1004FA 38,400 BTU
Do you recommend Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas?
Answer
Answer
How do you restart the kenwood heater after the safety device turned it off?
Answer
what are the vertical, horizontal and front clearances for the exterior exhaust vent?
Answer
I have a Rinnai Energysaver 1001ft it has the outlet at the back for the heater ducts. I, however... (More)
Answer
I would like our Rinnia 1001ft to blow heat out the front grill and not the rear duct how do I... (More)
Answer
rinnai energysaver 1000ft I havent used it before - we just bought this house with it instaled. when... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Rinnai RHFE-1004FA 38,400 BTU...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
