Question about RCA TH1101 MP3 Player
First time user
Please walk us through installation procedures.
  • 2 more comments
  • ann384 Jan 08, 2008
    it just wont download songs
  • Anonymous Jun 19, 2008
    mp3 wont download songs from i tunes or lime wire. not sure if im doing it correctly. i download songs from limewire which then went to my library, then tried to download them onto mp3.
  • LMRS Aug 07, 2008
    I somehow managed to overload my mp3 player with downloads and deleted all my music files and I'm having trouble getting them re-downloaded to my RCA Pearl MP3 player.
  • howie_1955 Aug 16, 2008
    need to know how to add aand delete songs?
  • 8,596 Answers
Peanut -
use your QuickStart Guide - available on RCA website if you lost it - or call RCA - plug in your mp3 player and load the CD - if the CD won't load, you may have a non-compatible version of Windows - go to RCA's website if you have Vista, because they have updated software/revised instructions
ann-
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Make sure the songs are in the correct format. Make sure the songs are not AAC, WAV, streaming, or some other non-supported format
Mp3 players are more complicated than ever. This player may only accept DRM-encrypted WMA files. I would first check the songs that you have downloaded to make sure they did not have "temporary" licenses with a fixed end date. You can do this by right clicking on an individual song, clicking on properties, and selecting the "license," "digital rights mgmt" or "media usage rights" tab - the wording varies by configuration. It will give you info on the license. If the song says that it has no license, it will not work with this player. One remedy is to use mp3 converter software to convert all of those wma files to Mp3's - I don't know of any free ones, but you can certainly look for free Mp3 Converters. Another remedy on unlicensed songs is to hit the "acquire license" link in the license tab, if one exists.
-Tha Mp3 Doctor
Posted on May 24, 2008
Walking belt slipping
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Dec 22, 2013 | Precor Exercise & Fitness
I have a 2005 Precor 9.27 that I bought used with only 500 miles on it. This is my first tredmill and I feel it silpping at 5 mph. How do I tighten walking belt? The alignment bolt is at rught rear,so
Dec 07, 2012 | Precor 956 Remanufactured Treadmill
I AM NOT ABLE TO INSTALL THE ROUTER AND PLEASE ASSIST ME WITH START BASIC PROCEDURE.
Hello an good day i am sending you a url which will walk you through setting up your router it has text an also a video to walk you through it.
http://www.tech-faq.com/how-to-setup-a-linksys-router.html
Please reply back if this did not resolve your concerns or if you have any other questions.
Nov 05, 2010 | Linksys WRT54G2 Wireless Router
I have noticed a few times that my f3 life fitness treadmill changes pace on me, and so does the incline. i can see it on the monitor, also it has started feeling like the belt is catching or something, or...
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
Jul 18, 2010 | Life Fitness F3 Folding Treadmill with...
Belt is slipping,
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill running belt adjustments.
Jul 06, 2010 | Life Fitness 9000 Next Generation...
After loading from both recovery disks, installation stops
THIS IS A NORMAL PROBLEM WITH ALL WINDOWS VERSION. YOU CAN NOT SOLVE THE PROBLEM. JUST RE-INSTALL THE WINDOWS TO YOUR PC. ONLY THIS WILL HELPS U.
BYE
KETAN
Feb 18, 2009 | HP Compaq Presario Media Center SR1750NX...
I have a cd to install in my lap top which is windows xp,because my lap top has nothing on it, but i have lost the product key for it can you help me please
Hi There,
Product key replacement is easy but done solely through Microsoft. Here's how:
Click here to bring up Microsoft's product replacement page.
Scroll down a few lines.
On the left side, under the 'More Information' header, click on 'Replacement Product Key'.
This will walk you through the procedure. You'll be up and running in no time.
Mike
Oct 10, 2008 | Microsoft Windows XP Home Edition
Procedure for installation
Although we are not real familiare with Tally 8.1, there is a PDF file that explains the installation process depending on what exact version you have e.g. Silver (single user), Gold (multi-user) etc.
Here is a shortcut to the PDF file explaining it all. Thank You!
Dec 18, 2007 | Computers & Internet
RCA TH1101 MP3 Player Logo
53 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
