This most likely a RAM problem. The memory RAM module/s maybe faulty or they may only need re-seating so they make proper electrical contact. Re-seat the RAM module/s and see if the Toshiba boots up properly.
If it still doesn't boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test them for you.
One of two things... bad or missing memory will cause beeping, but I assume if you know the keyboard is not responding then the PC has booted up. The other thing to check is a stuck key. Look and see if there is one key that appears to be depressed. If that does not reveal the bad key try rubbing your hand across the keyboard, pressing down on the keys as you move your hand across. As a last resort you might try tapping every key several times to release the stuck key.
I've had my Satellite A215 for a little over two years and I've never really had any problems until...
(More)
I've had my Satellite A215 for a little over two years and I've never really had any problems until now.For the past couple of days my laptop will be plugged in, but it will suddenly stop charging and the battery light will start blinking orange and the power light will turn a wierd blueish orange color. If I mess with power cord for about half an hour (unplugging it from the laptop, then the outlet, then disconnecting the cord from the power brick, etc.) it will eventually start to charge again and the lights will go back to normal. Do I need a new battery or a power cord, or both?
i have toshiba satillite a105 laptop, just now i tried upgrade the ram. after that the diplay...
(More)
i have toshiba satillite a105 laptop, just now i tried upgrade the ram. after that the diplay disappear. now the power led is blinking slowly.
i have toshiba a100 .. its not turning on.. when i put the charger on and power on botton its flash...
(More)
i have toshiba a100 .. its not turning on.. when i put the charger on and power on botton its flash bettery light 5 times .. but not turning on .... plz help me to solve this prob...
