Question about HP OfficeJet 6110xi All-In-One Thermal Printer
Broken printer cartridge carriage - where can I find this part?
Does anyone know where I can get this part or if it can be installed or replaces?
  • 233 Answers
What to do when the carriage of the cartridges HP Deskjet 350 doesn't move?
i think your not using this printer log time...?????
just conform before its working or not after replacing new cartridges it showing this erorr??
if it is not working when you installed new cartridges, your new cartridges fault other wise problem with carriage PCA board
Apr 20, 2014 | HP Deskjet 350 InkJet Printer
Empty carriage stuck in my HP 7500A printer
Hello,Lester Makang
Your carriage got stuck in service station,is there any noise coming from the right side of printer then there will be broken gear.
Power on your printer,after you got carriage jam error open cartridge access door and wait 5 second when you see that gears trying to move,use your hand to pull your carriage to left side.Don't use much force.If your carriage got free then install your print head and cartridges.If this will happen again then take it to service center they will change the service station or broken gear but the cost goes much high.
Nov 06, 2012 | HP Officejet 7500a E910 Multifunction...
I replaced my color cartridge on my HP Photosmart C3100 series printer and now it is making a grinding sound, but prints perfectly fine - what is the problem?
You would want to try and reinstall the print cartridges. It is possible that something is just stuck that is why you are hearing the grinding sound.
Let me know.
Apr 06, 2010 | HP Office Equipment & Supplies
My printer carriage won't move???? It is an HP C 4180 printer. I put in a new black ink and it jammed. I know how to install the ink and nothing happened that was different except now it won't move. Can...
Make sure the cartridge is firmly seated in its holder. It's possible that the carriage belt has broken or has slipped off the motot pulley. Look inside the printer and locate the flat toothed belt that pulls the carriage back and forth. follow it to either end and make sure that it isn't broken or slipped off the motor.
Jan 24, 2010 | Office Equipment & Supplies
Need instructions on how to install a HP 6110 Cartridge Return Belt. The belt came off but does not appear to be broken.
Hello HP 6110 Cartridge
Issue : installing Cartridge on HP 6110 Printer
Printer :Desk jet HP 6110
Analysis : it seems that you are trying for Replacing the print cartridges
Solution : Please try the following steps to replace which is very simple and easy. The most important part is to understand and then apply without fear..
1) Turn on the power of the printer
2) Lift the print carriage access door on the front of the unit
Observe : the print carriage will move into the middle of the access area.
3) Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch (You Need to Press Of force Single finger on the top of the Carriage Latch) and then pulling the lower section of the latch forward. Lift the latch.
4) Grasp the sides of the ink cartridge and pull the cartridge out to remove it.
5) NOW by
Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage.
Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch).
6) Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur.
7) Close the print cartridge access door..
Now check the by running a test print
Click Start , click Settings , and then click Printers .
Right-click the all-in-one print icon and click Properties
On the General tab of the Printer properties, click the Test Page option.
Try the above steps hope the best out of it
Happy new year
Jan 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I traveled to NY and now my printer gives me a message that the color cartridge is not installed properly. I changed the color cartridge, turned the whole system off and still same message color cartridge...
There is a tiny switch where the ink cartridge goes at the bottom of the carriage assembly. If that switch is broken it will never see the ink. Unfortunately it's probably a shop repair to change the carriage or print engine.
Jul 09, 2009 | Canon PIXMA iP90 InkJet Printer
I have the epson R200 and the ink carriage will not move across the printer anymore. You can manually move it back and forth freely.
Does anyone of you have a diagram that shows how to replace anEpson R320 Inkjet Printer Carriage Delivery Belt ? I have two of them. One has a belt broken and the other the black cartridge does not print (I have replaced it with a new cartridge and have cleaned the heads etc.) Any suggestions? If so, please email me at ril-2000@surewest.netThank you
Feb 28, 2009 | Epson Stylus Photo R200 InkJet Printer
Broken ink cartridge holder: Xerox WorkCentre 470CX
Usually when part of the Carriage is broken, it involves taking the Carriage Assembly apart which also deals with the head assembly, Timing , etc. I would call your local Xerox dealer or printer repair depot. Get an estimate then make a decision whether it's economical to have it repaired.
I could not find a service manual for your unit. I did find this on Xerox's site:
If the Ink Cartridges do not snap in straight or seem loose, the Carriage may be broken and your WorkCentre will require service. Click "Email for Support" in the Please Help section at the bottom of this page to contact Team Xerox for service
1-800-ASK-XEROX or 1-800-275-9376
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 11, 2008 | Xerox WorkCentre 470CX InkJet Printer
Hp 6110 remove and check cartridge
this kind of hp printer, have often a specific problem with a cartridge carriage. If you can observe (with a flashlight) inside of cartridge carriage, on the right side of carriage, you can see a small piece of spring made from steel, which is moved from his place, because an broken little piece of plastic.
if you see the spring which is moved, you also may see the hole created by the spring on the electrical contacts of the cartridge carriage.
if you can see the hole... you have a very bad news.
i dont know how much cost the repair of printer, but I tell you, this printer is discontinued.
Sep 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110xi All-In-One Thermal Printer Logo
19 people viewed this question
Ben Johnson
