Home airconditioner Hi i have a split system aircon in my lounge ,following a transformer blowing up in our region the aircon no longer works,unit power light comes on but the outdoor compressor does not ,wondering which component may have been damaged ? thanks kevin
    Sergeant:
  • 288 Answers
Does any of the other functions work? the blower fan? (turn the thermostat to on not auto) or the a/c? If not, check the 24 volt transformer and the fuse on the board, if it has one. If you have a meter, set it to a/c and check the wires on the thermostat. You cant check to ground on this, so check red to white, for example.
Posted on Jan 07, 2008
My aircon does not cool already
If you have purchased this unit recently, return it and then go buy a different A/C unit... these units are junk and many do not even work right out of the box...
If you have had it for longer then the warranty, then junk it and buy a new one...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 05, 2011 | Heating & Cooling
My mother has an old 'no longer working' reverse cycle unit mounted in her lounge room wall. How does she get it removed, the wall repaired and finally, replace with a 'new'...
No, there is no complete package by itself, the skills required are completely different. But there are local companies that do it both - they employ 2 crews: a building one and an aircon one. You will need to contact different aircon companies locally and ask them some will do that themselves, with their crews, other will arrange for a separate crew to do the wall repair for them before installing the new unit. I can't tell you who to call simply because i do not live in your city.
But you could do some of the work yourself: to remove the unit all you will have to do is to disconnect the unit from the power, take out its securing bolts and just drag it out of the wall. After that you will have to plug the wall hole with some sheets of drywall - it's a 1 hour job, not counting the joint compound drying time and subsequent finishing.
May 17, 2011 | Heating & Cooling
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Aircon no longer responds to remote handset
Open the front again and make sure that the operation selector is set to remote control. If it is, then I suspect that your remote sensor reciever on the aircon unit is bad. It is very simple to replace.
May 06, 2009 | Heating & Cooling
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Airconditioner shows E2
Hi,the E2 symbol its min Medium speed,they have the problem error of your PCB Board,please nearest aircon service center to repair the PCB Board.
Dec 16, 2007 | Heating & Cooling
Split system airconditioner Panasonic model CU-A28CKR.not responding to remote
Try turning of the power to the unit.Wait 60 seconds and try it again.This may reset the unit.
Nov 24, 2007 | Heating & Cooling
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
