I have a HCL473W with a 'concave' screen effect on two of the three colors. I read a number of peoples comments that the IC's were the problem on the convergence board, however, from reading on here, it appears that the IC's aren't even on the convergence board?? It appears that they are on a sub board, is it possible that people have been referring to the sub board as the convergence board by mistake? I don't want to buy the sub board ($140) only to discover that the problem was actually on the convergence board, which is really a 'card' in a shielded case? I do have the original remote and, I only watch about 1 to 2 of hours worth of TV a week! That basically means since I have had the TV for five years, it has about 500 hours of use!! I would have said that wasn't a good life for a TV?? Especially as we also have an old Philips CRT thing that has, I estimate, seen in excess of 15,000 hours of use and still works!
The convergence correction is a circuit centered around two IC's (STK...) in order to determine where the IC's are you would need to remove the back cover of the set and look for them. It's ussualy too expensive to change the whole board since the convergence circuit is only one part of the board. Check info below for a good idea of what's involved. convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks! See link for more detail http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
You don't need to replace the whole board, regardless of which board it may be mounted on. The STK IC convergence chips alone are all that need to be replaced. You can order them from a number of different online sites. You can try Alibaba.com. If you have any more questions, feel free to ask!
picture went out turned set off ,then turned set back on now picture is mostly green and blue ,reset...
(More)
picture went out turned set off ,then turned set back on now picture is mostly green and blue ,reset all setting back to default settings that did nothing
when you plug in timer light is on no power light get no picture or sound it is a samsung hcl473...
(More)
when you plug in timer light is on no power light get no picture or sound it is a samsung hcl473 sept. 2002 at first tv would come on everthing worked fine then would go off now nothing.
It worked fine one day and then the next it wouldn't turn on. I had a repair man come and he...
(More)
It worked fine one day and then the next it wouldn't turn on. I had a repair man come and he suggested that I spend my money on a new TV. He pointed out a large module with cards or smaller modules sticking out of it and said the whole thing could be bad or just one of the cards. He's quoting anywhere from $300-700 for the repair. If I new what the part was that is bad I would order it and install it myself, but he never gave me a write up of his findings. My TV is only 6 years old which I think is way too early to send it to the junk heap. Any suggestions?
After initial start, for approx 3 minutes with good sound and picture, the set flops into a standby...
(More)
After initial start, for approx 3 minutes with good sound and picture, the set flops into a standby state. The power light never comes on and the timer light is flashing all the time. Every couple of minutes it will try to come back on but imediatly flops back into a standby state again Any Ideas? Thanks LWR
