Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista HomeBasic 9980286710 PC Notebook
Problem for Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista...
ACER ASPIRE 3680 LOOKS LIKE INK IS BLEEDING INK INSIDE OF IT..
By siahkyaty on Nov 08, 2009
I have a cracked acer aspire 3680 screen. It happened by me picking up the computer by the display and i guess pushing to hard on the screen and it cracked internally... Now there is a big blob on 75% of my screen and it looks like ink... You can also see little rainbow colored lines as well. I saw somebody on youtube change their lcd screen though... If i did the same thing they did will the lines and ink go away? Is that how you fix a defective screen? How much do acer lcd display run and how much are general service fees? Because what the man did on youtube looked like a farely easy and quick repair...
Solution #1
posted on Nov 08, 2009
Not Rated)
Geekman
Rank: Guru  Acer Computer Hardware  Expert
Rating: 85%, 1720 votes
The cost of the screen and repair depends upon the size of the screen and how difficult it is to replace. You need to get a quote.
The LCD screen needs to be replaced. If you feel this task is difficult then go to LCD Parts for service, parts and DIY info - click on this link to their WEB site :-
www.lcdparts.net
Was this helpful?
Yes
No
Solution #2
Not Rated)
dupalopez
Rank: Guru  Computer Hardware  Expert
Rating: 93%, 19 votes
It indeed is a fairly easy repair in case of your Acer. However you will need a replacement screen which would cost a lot if you order it new. You might be better off searching ebay for a broken "donor" laptop (make sure it's exactly the same model, as even similar models with same screen dimensions might have different connectors or inverters - I learned the hard way ;)
Good luck,
Raf
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 3680
Questions and Unsolved Problems for Acer Aspire 3680
Do you recommend Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista HomeBasic 9980286710 PC Notebook?
Answer
Answer
Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista Acer Aspire 3680 will not boot up Answer Acer... (More)
Answer
Hello Is there a way for me to down load recovery disc for Accer 3680-2682.
Answer
bootmgr missing on a acer 2930z. Havve no reboot disc etc. plz help...
Answer
isatap #14, 15,16 is flaged on the computer. what does that mean...does it have anything to do with... (More)
Answer
i have problem with my ctrl key it is always pressed example when i press only (F)then its open find... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 3680...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
