I have a Viewsonic VX715
The issue with this particular unit is that the picture goes blank few...
(More)
The issue with this particular unit is that the picture goes blank few seconds after it is turned on.
If you turn the lcd off, on, off, on, off, on, off, on. Or change a resolution a few times it eventually starts to work and works properly untill turned off for a certain amount of time.
There is not much inside the lcd, only the power board and a signal input board, for a lack of a better name at this moment.
The backlight is perfectly fine, picture and backlight are both not operative untill turned on and off a few times.
Do I suspect correctly that the powerboard would be the issue in this case, its a single layer board it would not be too difficult to replace any of the components on the powersupply board if required
both inputs have the same issue, does not appear to be a input issue.
picture / backlight come on and work perfectly for around 2-5 seconds at first, after which the display goes completely blank but power light remains green.
resolution can be changed and the picture will return for a moment with good backlight as well, after a certain amount of on, off, on, off or resolution switching the display operates perfectly for unlimited amount of time untill turned off again after which - being cooled down the on off routine has to be repeated.
I've had the display apart a few times now and I can not find anything wrong with the boards.
maybe someone with more experience can help me as to what to look for or what components I might have to obtain and replace from the powerboard to get this to work like new again.
Printer indicates "printing" and receiveing "data" but nothing prints and I cant...
(More)
Printer indicates "printing" and receiveing "data" but nothing prints and I cant get the printer to reset. I turned the printer off, unplugged it and let it sit. I removed the ram hoping that on reseating it would clear itself but nothing has worked. Printer has been down for 2 days
Our colour Ricoh SPC811DN printer displays the following error message: Service Call SC548 Please...
(More)
Our colour Ricoh SPC811DN printer displays the following error message: Service Call SC548 Please Call Service HOW CAN WE REPAIR THIS? THANK YOU
my printer prints black pages perfect, when attempting to print color my yellow is out of line by 2...
(More)
my printer prints black pages perfect, when attempting to print color my yellow is out of line by 2 mm, so I can not print green , orange, or any color that needs to be mix with yellow, I have bought a new set of drums and a transfer unit and the problem remains the same. When you try to calibrate through the menu, it fails and this message comes up,error occurred sc285, functional problem, turn main power switch off then on if error appears again, call service. it there a way to manually adjust the yellow color by 2 mm left or right, has any one experience this sort of problem before how was it solved. please email me a link that I can get a service manual download.
