Home | Dell | Dimension 5100 (D51L1) PC Desktop | Dell Dimension 5100 com...
Dell Dimension 5100  PC Desktop
Problem for Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 computer with error
By hecktic1 on Nov 08, 2009
Have a Dell Dimension 5100 computer. It powers up and you see windowsXP screen. The it goes to stop error screen. Stop: 0x00000024,(0x00190203),0x86FD3570,0xc0000102,0x00000000 What does it means?
Solution #1
posted on Nov 08, 2009
Not Rated)
kisssmooth
Rank: Wiz  Computer Hardware  Expert
Rating: 84%, 22 votes
There are two ways,
1, If you still can access Windows, try to disable any backup programs, virus scanning programs or disk defragment tools. Try also to run a hardware diagnostics tool to detect any errors your hard drive might have. And run chkdsk /r to detect and repair any file system structural damage.
2, If you are unable to load Windows. Then you should try to access your ntfs partitions by making a ntfs boot disk with NTFS4DOS (freeware). You can download it from http://www.geekswhoknow.com/files/ntfsinst.exe You will need a floppy disk.
After you load the bootable floppy disk onto your damaged system, select either option one (1) or option three (3). If you selected option one (1), type chkdsk /r at the command prompt, and your problem should go away after the disk has been repaired.
Note! Unfortunately there is a chance that your partition is corrupt beyond repair and all of your data is lost. In that case, you need to reformat the partition to be able to use it again.
Additional information can be found at http://support.microsoft.com/default.aspx?scid=kb;en-us;Q228888
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 5100 PC
Questions and Unsolved Problems for Dell Dimension 5100 PC
Do you recommend Dell Dimension 5100 (D51L1) PC Desktop?
Answer
Answer
I have a Dell Desktop , bought a cable to hook it up with my tv, also using a hd15 vga splitter,... (More)
Answer
HP Pavilion Slimline s3122x powers up fan runs but no monitor working or keyboard took to shop was... (More)
Answer
how can i clean my comp. drivers for free
Answer
recieve error message when trying to setup zune system to dimension 5100 0x8007063 what wrong is it... (More)
Answer
I CAN play MP3s and CDs and hear the music on my myspace page when it loads. I can hear music on... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Dimension 5100 PC...:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
