Question about Creative Labs ZEN V Plus MP3 Player
Freezing My zen keeps on freezing and I've tried to reset it. After I reset it it is still frozen. What can I do?
    Novelist:
  • 167 Answers
Using the instructions below try Cleanup first, if that doesn't work... (if you have a backup of all your music on your computer), try the format option
This is from Creative's website:
Zen V Plus and Zen V
  1. Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Message Edited by Jason-CL on 09-11-2006 12:02 PM
Forum Administrator
Creative Labs
Posted on Jan 06, 2008
4 Suggested Answers
Stonebraker
  • 167 Answers
SOURCE: my zen is freezeing
1. I'd try a system clean up first (instructions below)
2. definitely upgrade your firmware (http://us.creative.com/support/downloads/)
3. If all else fails, back up all your music on your PC and format it (instructions below)
.... from Creative's site
Reset, Format or Clean Up a Zen Vision:M If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off. If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. vision_m_reset1.jpg
  4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
    • Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
    • Format All (Formats the players hard disk - Note: all contents will be lost)
    • Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
    • Reboot (Reboots the device).
  5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
issy2
  • 462 Answers
SOURCE: Keeps on freezing
Dear sweetShea
you must upgrade ur zen for once to prevent it from freezing. If firmware is unstable freezing occurs. Hoping a good rating from u...!!!
Thankyou
Posted on Feb 15, 2008
TheGadgetDr
  • 65 Answers
SOURCE: frozen on start up
This sounds like it might be a hard drive problem. Have you tried to put it into Recovery Mode so you can troubleshoot it? Put a paperclip in the Reset hole while holding the power button in the On position. Then release the paperclip and continue to hold the power button until it goes to the Recovery Mode screen. You should at this point try Format and Scan Disk/Cleanup, then Reboot. If it still gets stuck at the same spot, then its going to be a hardware failure.
Click here to view my step-by-step troubleshooting guide.
Click here to send in your device for free diagnostic testing.
Posted on Sep 23, 2008
Zen V Plus freezes only when certain tracks are played -
First place the Zen in the freezer to help the firmware to stiffen up. Once frozen place in microwave for 25 seconds. This will reset your device and all should be good.
Sep 19, 2009 | Creative Labs ZEN V Plus MP3 Player
Creative Zen V
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Nov 04, 2008 | Creative Labs ZEN V Plus MP3 Player
Frozen on start up
Sep 14, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Keeps Freezing
http://serviceman.site88.net/index_files/MP3Players.htm
Jul 04, 2008 | Creative Labs Zen Touch MP3 Player
My creative zen keeps freezing!
Hi -
I know this response is way late to help you, but I was having the same problem. I could turn the zen on fine, but as soon as I tried to play music it would freeze and I couldn't turn it off. Using the reset button didn't help any since it would still freeze if I tried to play anything.
But I found reformatting the entire zen totally fixed it.
-directions-
Connect your zen to your computer, go to windows explorer, click computer on the side bar, and your zen should be under "portable devices". Click on it. You should now be viewing the "storage media". Right click and select "Format...". This completely resets the zen, clearing any preferences or media you put on it and the freezing problem.
It was annoying putting all the pictures, videos, and itunes back onto my zen, but at least it works now. Since I've reformatted it, I have had no problems.
Hopefully this helps others who experience this problem.
--Lillian
Jul 01, 2008 | Creative Labs Zen Digital Media Player
Help frozen up zen vplus 4gb
I had the same repeating problem with my Zen V Plus 2GB. There is a tiny hole on the left side of the player, underneath the on/off switch. Stick a paperclip in there and press gently to reset your player. I lived for 6 months letting the battery wear itself out before I discovered this reset hole. I finally found the offending piece of music and deleted it from the player. I haven't had any problems with my Zen freezing since deleting that song. Pay attention to whether it always freezes on the same media, that might be the source of your problem.
Hope this helps!
Jun 27, 2008 | Creative Labs ZEN V Plus MP3 Player
Keeps on freezing
Dear sweetShea
Thankyou
Feb 15, 2008 | Creative Labs Zen V MP3 Player
Creative zen V 1GB
Boy's will be Boy's....
try this
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Dec 08, 2007 | Creative Labs ZEN V Plus MP3 Player
It Freezes Before It Goes To The Menu
This is important; because, if you cannot get into Recovery Mode, then this is a sure sign of a bricked player. You could try a forced hard reset by going in and disconnecting the battery, but chances are, the player is bricked.
try updating the firmware.
Oct 28, 2006 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
90 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
