My front load stalls at the Rinse cycle. It alerts with a continuous beep. If you hit the Start button again, it continues it's cycle. What will it take to fix it?
Frigidaire affinity front loader error 41, stuck on pause -- I had read someone's suggestion about...
(More)
Frigidaire affinity front loader error 41, stuck on pause -- I had read someone's suggestion about removing the ring and unscrewing the latch, (or something like that) and I can't figure out what the ring is and how to get it off lol Error 41 is that control panel thinks that the door latch is open. and says refer to Test 7... what is test 7 and how do you fix this problem?
I have a frigidaire washer Model#GLTF1670ASO. The washer will not pump the water out and spin out....
(More)
I have a frigidaire washer Model#GLTF1670ASO. The washer will not pump the water out and spin out. If the machine sets for overnight, the pump will run one cycle, then not drain anymore water. Help!!
when press start it blinks and press again it runs ok until it just stops and the start blinks and...
(More)
when press start it blinks and press again it runs ok until it just stops and the start blinks and shuts it off
